Humidification in winter
   / Humidification in winter #11
I used a stand alone unit for several years. Eventually, it died. Then I installed an Aprilair 600 on the furnace. I'm not an hvac guy but the install went quick (2hrs). I don't miss pouring gallons of water into the standalone unit everyday. It works great. The water panels are replaceable and cheap, 10 bucks each, and are good for quite a while.
Thanks for the replies. For those who have humidified successfully I have a question: are you doing it with mineral-laden water? Most any humidification system would be trouble free for years if the water has no minerals. Otherwise, evaporation will leave behind crusty minerals requiring frequent access for cleaning and/or replacement.
   / Humidification in winter #13
Like the previous poster has, an aprilair 600 takes bad water like a champ. Basically if it finally loads up you simply throw away the water panel and soak the guts in vinegar. It is one of the most simple setups there is. There really is no good way around a humidifier loading up unless the incoming water is treated. Be glad you are just small scale humidifying. The big jobs are high dollar and turn themselves into a ball of concrete exceptionally fast.
   / Humidification in winter #14
I haven't been able to find a Bemis Waterwheel to replace the one we had. We did pick a freestanding cabinet model up at Sears several years ago that takes 4 pads at a time. They aren't cheap and it usually takes 2 or 3 sets per heating season. Bad thing is this one doesn't do the job like the Bemis did. We have hard water and cleaning the humidifier takes either CLR or if it gets real heavy, muriatic acid.
We also tried a couple different duct-mounted humidifiers that didn't work very well. The only good thing about the duct-mounted humidifiers was that one became a "donor" for the cabinet unit we have. It's located in the dining room and I ran a 1/4" water line to it. Using the float valve from the duct unit allows it to fill automatically. I cut an electrical outlet box in the wall, fished the tube from the basement and trimmed it with a telephone plate. The tube comes out through the 3/8" hole in the plate and there's a 1/4 turn valve in the basement. In Summer we can turn it off and disconnect it.
   / Humidification in winter #15
If you're getting salty buildup from treated water put into a humidifier then chances are your treatment system isn't working properly. Salt is what's used in the brine solution/media that functions to trap and send excess minerals to drain in a softener system. Properly softened water should be essentially salt free. See below for one example:
http://www.waterboss.com/watersoftenermyths.shtml:
"Although many people believe that water from a water softener contains too much sodium for consumption, most do not realize how little sodium is in soft water. The average amount of sodium in a quart of water from a properly working water softener is 75 to 100mg as opposed to 120 mg in a slice of white bread."
BTW, my wife worked for a water treatment firm for nearly 15 years, and our water is very high in iron. We have softened water, reverse osmosis drinking water, and oxygenated water to treat high levels of seasonal sulfur odor.
   / Humidification in winter #16
Yes we have well water too and use "Sunbeam humidifier liquid treatment" and seems to work great
We think our hardness changes over time. Sometimes the softener regenerates too early and sometimes too late so it is difficult to select a hardness value. We have it set at 10 which seems to be the best all around choice. There are times when we get excess soap suds which may appear as a malfunctioning softener but is probably due to hardness variation. That's my best guess. An accurate way to measure hardness would be great but the strips I have seen can't see the difference in 20 and 100 grains/gal. I want to measure it many times over many months. Our well has 2 sources: 6 gpm at 60' and a total of 25 gpm at 160'.
That sounds good but I want my unit in the house so I don't have to negotiate an unforgiving crawl space.
I think humidifier manufacturers figured out they can make a lot more money of they offer only wicks that are not reuseable instead of filter belts. The Bemis filter belt lasted us until the unit rusted apart.
   / Humidification in winter #20
How about hooking up a Reverse Osmosis filter before your water softener and using that to supply water to the humidifier? That should cut WAY down on how much junk builds up on the filters.
Aaron Z
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
CAT CS563 (A47477)
CAT CS563 (A47477)
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
