Comparison Husqvarna GT48DXLS Compared to John Deere
   / Husqvarna GT48DXLS Compared to John Deere #181
I scratch my head wondering why guys want to mow like it's the Indy 500. My JD X590 tops out at 7mph but I never mow that fast. The only time I go that fast is when I get a wild hair to do some hot doggin'.
I don't see why I would want to spend 3 hours if I can buy a reasonably priced machine that is built to do it in 1.5 hours. My cut quality is actually very good and I run at the full available speed at almost all times. Slowing down doesn't make any sense from where I stand. My yard is kept like a golf course, even at 6 mph cut speed.
   / Husqvarna GT48DXLS Compared to John Deere #182
It is astonishing how manufacturers can make mowers that provide an excellent cut at 10,12 and even 16mph. In considering one of these new Husqvarna models I am torn between the G730 and the K66. I like the idea of having a locking differential for the day when I choose to haul stuff or maybe push snow with it, but I like the fact that the G730 has a filter for easy maintenance and Hydro-Gear provides excellent documentation for servicing their transaxles. My yard is relatively flat and I never need to cut when the grass is wet, so the locking diff would only be for if I get the dozer blade and a massive lawn roller!
   / Husqvarna GT48DXLS Compared to John Deere #183
If you have a flat yard, the G730 would probably outlive you. I live on a freaking cliff and I have 580 hours of extreme or use on my G 730. I have wheel weights and chains on mine, and traction has never been an issue. I can stand the front end up in the air while climbing a 34 degree angle incline, and a tire will never spin. I worry a lot more about death by rollover than I do about lack of traction.
I do change the filter and fluid every 2 years in mine.
   / Husqvarna GT48DXLS Compared to John Deere #184
People will mow as fast as the lawn lets them, being comfortable. I have a smooth looking lawn that I cut with a 84"rear finish mower and at second gear it maxes out at 7 MPH. Mowing at that speed is iffy at times because of rough spots here and there. Faster is out of the question even though I could cruise at 15 and mow because the ride would throw me off the tractor and corners would chew up so much time and lawn.
My X740 can cut quite fast but because of lumps and dips etc.but wide open isn't feasible all the time.
   / Husqvarna GT48DXLS Compared to John Deere #185
Yep, cut at 6 and it's no issue. I plug and roll my yard, so it's pretty dang smooth and fast. If the machine were faster, I'd cut as fast as I could maintain a perfect cut. I wouldn't over speed what the blades can cut perfectly otherwise I'd have to make repeat passes. But I've never had that issue with the junk I run now.
   / Husqvarna GT48DXLS Compared to John Deere #186
I guess I am fortunate that I am never really in a hurry when cutting the grass so I don't really know how fast I am going or how long it takes. I want to say that my Exmark tops out at just over 7 but I just cannot go that fast without leaving wavy lines.
   / Husqvarna GT48DXLS Compared to John Deere #187
Here it tis: Prob the direction I am going to go. Fab deck, Kawa engine, BIG wide tires, commercial grade trans, differential lock and its a big mower.
"Heavy duty garden tractor with unbeaten capabilities in its class. Versatile ClearCut cutting deck and powerful, reliable engine mean fast mowing anytime, anywhere with a perfect result every time. Commercial grade ground-engaging transmission with dash operated differential lock works with large, wide rear tires to enable tough usage without overheating, plus great traction and less damage to the lawn. Improved quality, comfort and ergonomics for an optimal driving and ownership experience.
Motor/engine manufacturer: Kawasaki
Transmission type: Commercial Grade Hydrostat, Electric Locking Differential
Cutting width: 48 in
$3,399.95"
Husqvarna Riding Lawn Mowers TS 348XD
   / Husqvarna GT48DXLS Compared to John Deere #188
What exact model of transmission is in that? I'm looking at the TS348 and would like to know what Tuff Torq exactly is in it as well.
   / Husqvarna GT48DXLS Compared to John Deere #189
The parts manual lists ...
1 – – – – – – Transaxle, Tufftorq K66ELD (580402201)(Order parts from transaxle manufacturer.)
   / Husqvarna GT48DXLS Compared to John Deere #190
Lowe's carries the TS 354 D. The Husq catalog link I gave calls it a TS 348 XD, not sure what the X is or the difference. Lowes has TS354 for $3299 and you can buy a 5 yr warranty for about $375 IIRC. The TS 354 is a 54 in cut. The TS 3xx has been around a few years and has great reviews...from the folks in England and Aus????
I am trying to find out what the X is, if any one knows or has a good guess post up with it.
The commercial grade trans really get my attention due to the hills, STEEP hills I need to mow.
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
