hyd control valve on 3 pt
   / hyd control valve on 3 pt #41
winston, My system doesn't have the B like in the link you posted. I assume the B is where you are indicating the relief is. There is nothing under the big shut off screw.
My filter screen is clean. Since I've had this tractor, I changed the hyd oil, Last yr I changed over to Transmission fluid.
I shut the big knob off and the 3 pt holds.
At idle with big knob all the way out. the 3pt will drop. It will raise back up at about 1500 RPM
I think I solved the slow loader issue. When The tractor is first started in the AM. loader speed is great. It seems like I lose some loader speed after using the tractor for several hrs straight. I think the oil is getting hot and thinning out causing me to have to run higher RPM to get the same flow. I think I'm going to experiment with thickening the HYD fluid some (maybe add some STP) and see if that helps with the thinning of the HYD oil when it gets hot.
Clem, I intend on keeping the tractor even though I'm looking for a larger (50-55 HP) tractor . So, I may as well have it working right. I think they have those valves made in china. Probably why they go bad so often. LOL
Carey063, I have no idea what you mean by a kenmac/ winston thread. I have read and appreciate all the comments. I didn't comment about the dirty suction ,because I know it's not dirty.
dump that transmission fluid and put some 303 fluid into it. You don't have to throw it away, catch it in clean buckets. Any heavy equiptment site would have some they would give you free. If I was closer I could give you tons that my loggers go through.
303 fluid was on sale black Friday at TSC for $16.99 a bucket!!!:eek:
   / hyd control valve on 3 pt #42
Yes, I believe as it gets hot, The fluid thins out too much causing everything to slow down.
At first, I thought it may be something to do with the 3pt control valve. After using the tractor first thing in the mornings, I really noticed how well the loader works until it gets hot.
It did the same thing with the JD303, which is why I switched to transmission fluid.
I believe tractor Ernie used transmission fluid in all his yanmars and never reported any problems.
wasn't Ernie in the Pacific North West or was it Pennsylvania? Penn would be closer to the souths climate in the summer but the PNW is nothing like your climate down there.
Well, I guess now it's a Scotty, Clem, and winston thread.. LOL
On a serious note. Yes Scotty, My thinking was /am, I having 2 separate issues being caused by the 3pt valve, but I really don't know for sure.
I am going to replace that valve as soon as Fredricks gets them off the boat. LOL . Maybe, just maybe, replacing the valve will cure both of my issues.
As stated earlier. When I first start using the tractor /loader I can lift a full bucket of what ever at around 1800 RPM. As the day progresses, I have to raise the RPM to about about 2500 to raise that same bucket full.
Clem, The loader did this same thing with original JD303 fluid I bought from JD dealer.I paid more than that for it at JD.
Only reason I changed to transmission fluid was to see if it made any difference . Nothing changed, I get the same results with transmission fluid as I was getting with JD303.
I still have the JD303 fluid in buckets somewhere .
After adding some STP to the mix, I was able to lift that bucket full all day at around 1800 RPM.
It's about to start turning cooler here, so It may be next summer B-4 it's hot enough outside to notice any change in loader performance when fluid gets hot.
If the new valve don't fix it. I'm going to load it up and take it to Fredricks and let them fix it. While I'm there, I can look at some of the Mahindra tractors he has
   / hyd control valve on 3 pt #44
I have read a not so stellar review of a Mahindra tractor on another forum I am on. Everything from cylinders leaking to metal parts needing re welded, bucket quick connects coming off causing damage to pins in the traN's mission coming out causing the loss of low range. If interested PM me I will send you a link. I know they dont like links to other forums here.
   / hyd control valve on 3 pt #45
I have read a not so stellar review of a Mahindra tractor ...
There are similar posts here. Enough to give me second thoughts. Mahindra sources tractors and components from all over.
I would study which models are best, before considering one. None of the modern tractors are as simple and bulletproof as what we already have. Or as owner-maintainable.
   / hyd control valve on 3 pt #46
I would put a good word in for the Kioti. My Bobcat is a Kioti with Bobcat written on it. It has been a dependable machine. It is a 2008 model so their might be more electronics now but not much more than the older Yanmars on the 2008 model. I too have heard some bad feedback on the Mahindras, mostly to do with electronic controls.
Yep, I have heard bad on them all with all the DPF, sensors, etc,.
As ya'll may remember. I bought that new Z turn Kubota only to burn the engine up @1.9 hrs.
Kinda hard to know what to get until you get it and just hope you encounter no issues
   / hyd control valve on 3 pt #48
After I posted I thought and the guy I'm thinking of cross posted the same thing on this forum as well. So the same story is here. I just can't remember his name. I will find it thought when I have time.
wow ! just googled several brands. Kubota, Kioti, mahindra, LS and JD.. They all had issues.
I believe one could google xxxx Tractor issues /problems and what ever tractor you inserted would come back with complaints.
What's a guy to do ? You can't google any brand, without some type of issue: HYD, DPF, engine, transmission, loader, 3 pt lift, etc, .
   / hyd control valve on 3 pt #50
Stay with old simple reliable, time proven designs! haha. No electronic diesel controls, no filters and sensors that derate your engine cause they don't like whats coming out of the pipe.
LOT: (2) Kimball Midwest 4-Drawer Hardware Cabinets, (1) 2-Drawer Hardware Cabinet w/Contents & (A59076)
LOT: (2) Kimball...
STORAGE FEES (A58018)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
More info coming soon! (A55787)
More info coming...
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
