Hydraulic chute rotataor
   / Hydraulic chute rotataor #11
The hyd motor only turns at a speed based on the GPM's applied.
You control the amount of fluid. Just provide the hyd motor a small amount of fluid.
Install a priority valve that will provide say 1 GPM, or whatever.
If you supply the motor I posted above, with 1 gal, it will turn about 120 rpm, and if you provide it with .5 gal, it will turn 60 rpm.
A 6.0 cu in hyd motor, using 1 gal will turn at 39 rpm, and .5 gal will turn it about 19 rpm.
If you go with larger displacement, the motor will run slower for a given input.
   / Hydraulic chute rotataor #12
Need help, please. Hydraulic rotator on my Kubota BX2750d only turns one way. cylinder on the rotator has 4 inputs. Currently using top two. Is this correct?
   / Hydraulic chute rotataor #13
Doesn't look like anyone replied. Yes, the hydraulic chute rotator only uses the top 2 inputs. The bottom 2 are the hydraulic pressure valve adjustments.
I have the same problem...chute only rotates 1 way. (on middle 2 (red/blue) on 4 way value. Strangely however, it rotates both ways when hoses are attached on top/bottom.
My Kubota dealer is looking into the problem. Did you get this problem fixed...if so, how?
   / Hydraulic chute rotataor #14
The control lever has two positions to the right. The 1st is basically for a slow, controlled dump if using a bucket. Push harder to the right and you're chute will rotate (and your bucket will dump quickly).
   / Hydraulic chute rotataor #15
Thanks; I found out about the far right detent (quick dump/chute rotate) after searching around this forum.
Strange that I could not find any documentation about this "feature" in the Kubota owners manual or the chute rotator installation manual.
   / Hydraulic chute rotataor #16
I'm learning by the seat of my pants; no manuals whatsoever. Picked up a used BX2230 with 400 hrs on it this summer. MMM, factory hard cab with heat and a brand spanking new 2750D blower strapped to a pallet. Decided to mount the blower a couple months back to be sure I had all the parts and new the sequence of assembly before the Canadians began exporting cold air.
Pretty simple stuff, only a minor adjustment to the shaft on the subframe and I was set. I installed an electric chute deflector, aft facing spot light, and a 12v power supply in the cab. Everything's greased and ready to roll.
It better snow like a MoFo.
   / Hydraulic chute rotataor #17
Sounds like a nice setup. I've learned a lot by searching/reading this forum, and I'm sure you will too. Good luck with your snow removal.
New/Unused SD Lanch SDLL50 Mini Skid Steer (A57453)
New/Unused SD...
2146 (A58376)
2146 (A58376)
207010 (A55853)
207010 (A55853)
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
Ford 8510 (A53317)
Ford 8510 (A53317)
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
