Hydraulic Filter Poll
   / Hydraulic Filter Poll #1
duane
Toro 266H and PT422
Just wanted to check to see what people are using for a hydraulic filter on the PT4XX series power tracs. I'm still using the PT hydraulic filter, but with a $50 min order, wanted to see what others are using. Post the filter make and number.
thanks
Duane
   / Hydraulic Filter Poll #2
NAPA 1551
Bob Rip
   / Hydraulic Filter Poll #4
thanks
Duane
I still use the PT filter. I just order enough filters to cover the $50 dollar minimum order as I will be using them eventually.
PJ
   / Hydraulic Filter Poll #5
I purchased a NAPA 1551 today. It is not the same as the Power Trac filter on my 2001 model. There are fewer holes in the filter and the gasket is 1/8" smaller in diameter than the Power Trac filter. It is also about 1/2" shorter than the PT filter. I took a couple pictures and will post them later, as I don't have time to dowload them right now.
   / Hydraulic Filter Poll #6
Speaking of filters, I am about 5 hours away from my 50 hour change out. Just disconnect spark plugs, take off the old filter replace with the new one after filling with fresh oil . Connect the hose to the port and turn the engine over until the fluid flows out smooth, and back into the tank right?
   / Hydraulic Filter Poll #7
Your right on track, should take only 5 minutes or so but don't forget on that 50 hour change to do the oil and filter on the engine also.
PJ
   / Hydraulic Filter Poll #8
Barryh said:
Speaking of filters, I am about 5 hours away from my 50 hour change out...
Be sure everything near the filter, filler and bleed port are super clean before you start. Also, a great suggestion that someone gave me was to use a quart sized plastic bag around the filter before you take it off. I did this today and only spilled a couple drops of fluid. Very good suggestion.:)
   / Hydraulic Filter Poll #9
When you find a substitute filter for your machine make mention of the name brand and size of engine that you have Moss has got a kohler I beleive as I do some have a robin engine that might help save someone some trouble. You might have been talking about the hydroulic filter if that is the case disregard this message.
   / Hydraulic Filter Poll #10
pajoube,
Thanks for the reminder I just changed the engine oil to Amsoil yesterday runs much smoother good stuff, glad to hear it only takes 5 mins. Great tip Moss will do thanks.
2015 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A50323)
2015 Chevrolet...
1996 CUSTOM ALUMINUM 16FT CAR TRAILER (A52141)
1996 CUSTOM...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
1994 GMC Top Kick Grain Truck (A50514)
1994 GMC Top Kick...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
