Oil & Fuel Hydraulic Fluid Level - L3400
   / Hydraulic Fluid Level - L3400 #11
I'm suspecting that I've been overfilling. Not good.
I would not worry. Back some years ago when there a lot of complaining about the ratchet noise of the old style cams Kubota instituted a change. They way over filled the hydraulic fluid to dampen the noise. I think the kit added a dip stick in the back since the sight glass would be useless.
Based on that, I don't think over filling will hurt anything except you won't see the level on the sight glass. In that case if it is all white it is low, if all a light yellow, it is full.
  • PTO NOISE.pdf
That's quite a relief to know about the overfilling, CCSIAl. I did go ahead and pulled the return line and let it pump out about 2 quarts. Fluid level still covers the sight glass, but I'll let it sit for a while and recheck it.
And yes, it is all yellow. But it's a relief to know that at least some overfilling won't likely blow the seals. I sure wish mine had come with the dip stick like the mod in the TSB.
Jim
   / Hydraulic Fluid Level - L3400 #13
this is what they did to mine and seems to work fine but the racheting can still be heard, albeit not as loud. what i don't like is the end of the dipstick protrudes from the cover and my boot sometimes catches it when i get on/off the tractor.
Blue Diamond 103709 (A53317)
Blue Diamond...
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2014 Peterbilt 388...
LOT: (8) Chain Binders (A59076)
LOT: (8) Chain...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
CATERPILLAR D6T XL CRAWLER DOZER (A52709)
CATERPILLAR D6T XL...
