Oil & Fuel Hydraulic Fluid Level - L3400
   / Hydraulic Fluid Level - L3400 #11
I'm suspecting that I've been overfilling. Not good.
I would not worry. Back some years ago when there a lot of complaining about the ratchet noise of the old style cams Kubota instituted a change. They way over filled the hydraulic fluid to dampen the noise. I think the kit added a dip stick in the back since the sight glass would be useless.
Based on that, I don't think over filling will hurt anything except you won't see the level on the sight glass. In that case if it is all white it is low, if all a light yellow, it is full.
  • PTO NOISE.pdf
That's quite a relief to know about the overfilling, CCSIAl. I did go ahead and pulled the return line and let it pump out about 2 quarts. Fluid level still covers the sight glass, but I'll let it sit for a while and recheck it.
And yes, it is all yellow. But it's a relief to know that at least some overfilling won't likely blow the seals. I sure wish mine had come with the dip stick like the mod in the TSB.
Jim
   / Hydraulic Fluid Level - L3400 #13
this is what they did to mine and seems to work fine but the racheting can still be heard, albeit not as loud. what i don't like is the end of the dipstick protrudes from the cover and my boot sometimes catches it when i get on/off the tractor.
204158 (A57193)
204158 (A57193)
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
