Hydraulic Fluid Overfill
   / Hydraulic Fluid Overfill #11
lacamo said:
Thank you soooo much for the suggestions. The oil is draining out right now and I've already bought the correct hydraulic fluid at the local John Deere dealer.
May I suggest you do it twice? Get every bit of "bad oil" out. I assume any residual 80W is a "bad" thing. Run for a bit, get it mixed, get all the hidden 80W out. I assume you cannot drain it all and that there will be some leftover oil. Dilution is the soultion.
Bob
   / Hydraulic Fluid Overfill #12
I'mm assuming you got a jd303 / hyguard equivalent oil? It will be fine.
Soundguy
   / Hydraulic Fluid Overfill #13
The way the hydro sump is shaped.. he could probably pour a quart of 'good' oil in and leat it drain.. or mineral spirits / diesel.. etc.. and it should drain right out. That thinner 303 oil will really thin up any leftover thick oil. In any case.. he's way better off with the UTF oil in it now.
Soundguy
That's just what I got. I let 'er drain for an entire day and then poured a quart or so of the hygard in, let it drain out and then filled it. I plan on using the tractor for some small jobs (a couple of hours work) and then drain/refill with new hygard. Thanks again!
   / Hydraulic Fluid Overfill #15
I doubt you will have two. If it gives you piece of mind, go ahead.. but a few oz of the old heavy oil, in those qts of hyguard will be fine. Your hyds would operate on aw46 which is thicker than utf...(which is closer to aw32.. etc.. )
Soundguy
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
