Hydraulic fluid/ Tranny fluid compaiible?
   / Hydraulic fluid/ Tranny fluid compaiible? #1
George_Martin
The hydraulic fluid in my snowplow absorbs enough water in less then a years time to freeze up the system. If I drain and refill with Dexron III will I have any compatibility issues with the remainder of the hyd fluid in the system?
   / Hydraulic fluid/ Tranny fluid compaiible? #2
Based on what we know about you, your tractor, its hydraulic system, the answer is a definite MAYBE. You need to fill in some blanks before anyone can help you. BobG in VA
   / Hydraulic fluid/ Tranny fluid compaiible? #3
OK....how about for an old Meyer plow/pump? /forums/images/graemlins/confused.gif
That's right!! My Western plow had tranny fluid and never a problem, but the Meyer plow has hyd fluid which has a real bad habit of taking in water and having problems when you need it most. If I just do the pump with red will the remaining hyd fluid mess things up?
   / Hydraulic fluid/ Tranny fluid compaiible? #5
That old fisher plow has had every thing from tranny oil to hydraulic to bar and chain /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif to get me through a storm when i had a leak.works fine.
ALAN
   / Hydraulic fluid/ Tranny fluid compaiible? #6
try plowsite.com with this question. They are very good with this kind of thing.
   / Hydraulic fluid/ Tranny fluid compaiible? #7
</font><font color="blue" class="small">( If I drain and refill with Dexron III will I have any compatibility issues with the remainder of the hyd fluid in the system? )</font>
My experience is that pretty much everything mixes with everything else w/o problems. Personally, I think compatibility issues are phantom creations made by marketing departments, but I'm cynical that way. ATF is super-cheap though, so if you are worried about it, drain the hydro, refill with ATF, then run for a few minutes while exercising everything. Drain and refill again and you'll be all set.
Jay
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
