Hydraulic fluid/ Tranny fluid compaiible?
   / Hydraulic fluid/ Tranny fluid compaiible? #1
George_Martin
The hydraulic fluid in my snowplow absorbs enough water in less then a years time to freeze up the system. If I drain and refill with Dexron III will I have any compatibility issues with the remainder of the hyd fluid in the system?
   / Hydraulic fluid/ Tranny fluid compaiible? #2
Based on what we know about you, your tractor, its hydraulic system, the answer is a definite MAYBE. You need to fill in some blanks before anyone can help you. BobG in VA
   / Hydraulic fluid/ Tranny fluid compaiible? #3
OK....how about for an old Meyer plow/pump? /forums/images/graemlins/confused.gif
That's right!! My Western plow had tranny fluid and never a problem, but the Meyer plow has hyd fluid which has a real bad habit of taking in water and having problems when you need it most. If I just do the pump with red will the remaining hyd fluid mess things up?
   / Hydraulic fluid/ Tranny fluid compaiible? #5
That old fisher plow has had every thing from tranny oil to hydraulic to bar and chain /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif to get me through a storm when i had a leak.works fine.
ALAN
   / Hydraulic fluid/ Tranny fluid compaiible? #6
try plowsite.com with this question. They are very good with this kind of thing.
   / Hydraulic fluid/ Tranny fluid compaiible? #7
</font><font color="blue" class="small">( If I drain and refill with Dexron III will I have any compatibility issues with the remainder of the hyd fluid in the system? )</font>
My experience is that pretty much everything mixes with everything else w/o problems. Personally, I think compatibility issues are phantom creations made by marketing departments, but I'm cynical that way. ATF is super-cheap though, so if you are worried about it, drain the hydro, refill with ATF, then run for a few minutes while exercising everything. Drain and refill again and you'll be all set.
Jay
RHINO DB150 LOT NUMBER 76 (A53084)
RHINO DB150 LOT...
Polaris Side by Side (A50324)
Polaris Side by...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
