Hydraulic Hose Guard
   / Hydraulic Hose Guard #11
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
Just takes a wrench to remove a hose end fitting.
   / Hydraulic Hose Guard #12
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
Log loaders get severe use. Around the grapple they use a heavy plastic spiral wrap.
   / Hydraulic Hose Guard #13
My tractor and loader came with that fabric hose protector on all of the hoses.
   / Hydraulic Hose Guard #14
Good planning. McCarr has this under "Abrasion resistant sleeving". I keep a selection of sizes on hand for a variety of protective uses, including hydraulics. My favorite positive is that it will stop a hydraulic fluid jet if the hose ever ruptures.
   / Hydraulic Hose Guard #15
I used the spiral hose wrap - like Big Barn pictured. Purchased at local "hydraulics shop" - House of Hose, Spokane, WA. Used on all exposed hydraulic hose.
   / Hydraulic Hose Guard #16
Here's some spiral, at close to the same price. A big advantage of the spiral is that it can be applied while the hose is installed.
That's where I got mine for the Grapple hoses,
   / Hydraulic Hose Guard #19
The price went up to $35 on Amazon because all you guys looked at it. :rolleyes:
I bought the exact same thing last June from Amazon for $27--Delivered. šŸ˜Ž
Here's a snip from my order.
JMR 40 Grapple (A47477)
JMR 40 Grapple...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2011 Land Rover LR4 4WD SUV (A55758)
2011 Land Rover...
CATERPILLAR 928F LOADER (A52707)
CATERPILLAR 928F...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
