Hydraulic Hose Guard
   / Hydraulic Hose Guard #11
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
Just takes a wrench to remove a hose end fitting.
   / Hydraulic Hose Guard #12
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
Log loaders get severe use. Around the grapple they use a heavy plastic spiral wrap.
   / Hydraulic Hose Guard #13
My tractor and loader came with that fabric hose protector on all of the hoses.
   / Hydraulic Hose Guard #14
Good planning. McCarr has this under "Abrasion resistant sleeving". I keep a selection of sizes on hand for a variety of protective uses, including hydraulics. My favorite positive is that it will stop a hydraulic fluid jet if the hose ever ruptures.
   / Hydraulic Hose Guard #15
I used the spiral hose wrap - like Big Barn pictured. Purchased at local "hydraulics shop" - House of Hose, Spokane, WA. Used on all exposed hydraulic hose.
   / Hydraulic Hose Guard #16
Here's some spiral, at close to the same price. A big advantage of the spiral is that it can be applied while the hose is installed.
That's where I got mine for the Grapple hoses,
   / Hydraulic Hose Guard #19
The price went up to $35 on Amazon because all you guys looked at it. :rolleyes:
I bought the exact same thing last June from Amazon for $27--Delivered. šŸ˜Ž
Here's a snip from my order.
2013 Fiat 500 Hatchbacks (A55758)
2013 Fiat 500...
4007 (A55851)
4007 (A55851)
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2006 MACK MR CAB & CHASSIS (A56129)
2006 MACK MR CAB &...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
2015 Ford Econoline Shuttle Bus (A55788)
2015 Ford...
