hydraulic motor chute rotation on a bx24
   / hydraulic motor chute rotation on a bx24 #1
muskokaBX24
Port Carling, Ontario
BX24
Anyone have any thoughts as to why my hydraulic motor that I am trying to install for my chute rotation on blower only goes one way when connected to the left right of the stick for my FEL. When I connect to the up down on the stick I get perfect rotation-so I now know it is not the pump...
   / hydraulic motor chute rotation on a bx24 #2
I'm going to guess your tractor has a regen function for your curl circuit.
   / hydraulic motor chute rotation on a bx24 #3
Yes, that is the reason...but to clarify things for the OP take a look at THIS thread where I detailed the issue, and also reference a good read on the subject.
There are always LOTS of threads like this around this time of the year! Search the term "regen" for more threads to read.
The long and short of it is you have to push the joystick further to the right past the detent...
Thanks guys,
The regen was indeed the problem. Thanks again for pointing me in the right direction. At the end of the day did anyone decide what was the best solution? What is the easiest way to limit the speed of the rotation if I have to jam my stick right and cannot feather it like I can when I go left. I have not had time to work through all the threads on it yet- just the Kennyd one.
   / hydraulic motor chute rotation on a bx24 #6
Unfortunatly, I don't think there is a "solution". This is something Kubota does backwards IMHO. Learn to love it;)
An adjustable in-line flow restrictor is the best way to adjust and "fine-tune" the speed to your liking. Take a look at this link: Surplus Center
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
