Hydraulic Oil (CK2610)
/ Hydraulic Oil (CK2610) #1
12Bravo
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
I have been researching oils for my service, I'm going to go ahead and change the Hydro oil along with the filter.
My book recommends several oils, but I can't seem to find them locally without going to the dealer with a mark-up on the price.
Recommends: Shell Donax-TD
Mobilfluid 424
Exxon Hydraul 560
Tractran UTH
Daedong UTF 55
Looking at some labels and other "Universal" oils I am not seeing a cross over. Way to many types to chose from and I don't know enough about them right now.
What are you all running in a gear shift Kioti's CK series?
/ Hydraulic Oil (CK2610) #2
My dealer said any 303 spec oil will work fine.
/ Hydraulic Oil (CK2610) #4
Others are ordering the Mobilfluid 424 on line. I used the TSC Traveller UTF. One of the specifics is it should be rated for wet brakes. I tried contacting Kioti and they basically said check the manual. I think the Shell Donex doesn't exist anymore.
BTW you are going to have a **** of a time removing the hydraulic filter that resides underneath by the right tire. Most people are using a chain wrench like the one I got from HFT for about $7. Nothing else will take it off. I added some red dye I got from Deere so the clear fluid is easier to see on the dipstick and also if you have a leak.
Red Dye, now that's a great idea. I was actually having trouble the other day seeing the dip stick.
I was actually thinking about shoving a screw driver through the filter and trying to spin it off that way. Had to do that on my truck when some jack who owned it before me tightened it so hard. Like he used the filter wrench to put it back on or something.
/ Hydraulic Oil (CK2610) #6
I added the dye to the tractor after changing the fluid. If I had to do it over I'd add it to the 5gal pail before adding it to the tractor. The local JD dealer ordered it and got in an extra. John Deere Oil MT3668
Others have used the screwdriver trick. It's kinda destructive and no-going-back solution. The chain wrench with an extension worked and only crushed the filter a little.
Well, called the dealership and they said just use an oil that is for a wet brake.
He said he uses Powertech or something like that. Said it was $60 per 5 gallons, I asked about other brands, well there wasn't really an answer more of an "I'm not an oil guy" comment.
/ Hydraulic Oil (CK2610) #9
Listen, strange women lyin' in ponds distributin' swords is no basis for a system of government. Supreme executive power derives from a mandate from the masses, not from some farcical aquatic ceremony.
I'm so proud right now.......:D:laughing:
/ Hydraulic Oil (CK2610) #13
Do you have a TSC by you? If so use Travellers Premium Hydraulic oil or a Rural King will carry Mobil 424.:thumbsup:
I have them here, I will check them out on the next hydraulic change in 400 hours....:shocked:
/ Hydraulic Oil (CK2610) #15
Members have posted that they have used the TSC, Travellers "Premium" Hydraulic oil with good results. If you go this route, there are two Travelers fluids. Look for the one that has Premium on the bucket.
/ Hydraulic Oil (CK2610) #16
I am looking to change mine as well on a Montana 2740. Tsc & Rural King has a 303 for wet brakes. It list a SAE 10-30. But the traveler premium doesn't list anything on that. I seam to have issues in colder weather and would like to go with the thinest I can get by with. Also hope that may help with gpm. Does anyone know?
/ Hydraulic Oil (CK2610) #17
The Traveler Premium is also a multi viscosity 10w-30 oil. I had to do a bunch of research years ago to finally find out the weight. My Kioti CK30hst calls for 10w30 hydro oil. Fel still slighty slow for the first 5 minutes when the temps are under 20'F but 3pt is fine. I think you'd be fine with either.
/ Hydraulic Oil (CK2610) #18
Thanks VictorW. I changed just the filter and it helped a great deal. Just bought the tractor so not sure what they may have put in it.
/ Hydraulic Oil (CK2610) #19
Mobilfluid 424
Exxon Hydraul 560
Tractran UTH
Daedong UTF 55
I believe my OM says the same thing about hydro oil.
I am about 30 hours away from the 200 hour change out. I do have a TSC close to my home so if this group feels the "Premium" oil is good quality, that's what I will go with.
/ Hydraulic Oil (CK2610) #20
I have had good luck tightening and removing my big hydraulic filter witih an ordinary but apparently a bit larger oil filter steel band type wrench. I always end up super tightening that big hydraulic because on both kioti's (ck20 and ck 2015) that bigblack hydro filter bleeds hydro oil. I have used that steel band filter for seven years now and despite my need to tighten the can I have always been successful removing or tightening with that particular wrench.
rimshot
2022 Horizon (A55973)
2010 Deere 318D (A60462)
2010 Deere 318D...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
UNUSED X-STAR GRAVEL LEVELER (A60430)
UNUSED X-STAR...
