SSdoxie
Elite Member
there should be no problem using a standard spool valve (cylinder valve) on a hydraulic PHD.  Posthole digger is designed to have optimum torques at low ratation speed.  Manufacture will use a motor of much larger displacement than adverstised/suggest flow rate of the pump supply.  This produces the same affect as gear reduction, with the slower motor RPM and higher torque not much risk of damage to the outlet shaft of the motor when flow is stopped.   If there is any concern regarding shock load at shut off, an external cushion valve can plumbed into serve same purpose as check valves in a motor spool valve.
