Hydraulic Post Drivers
/ Hydraulic Post Drivers #1
Bulldogger
Georgia
Kubota M9540, FORD 1920, Bobcat S300
Can anyone provide some information on tractor mounted hydraulic post drivers? What brand is best? How well do they work? What is the price range? What type of mount is the best, 3-point hitch, mounted on front of tractor to frame or FEL mounted?
/ Hydraulic Post Drivers #2
I can't be much of a help here other than the fact that my neighbor behind me has one (the brand eludes me), but he swears by it over a post hole digger.
He inserts a cedar post into this contraption and it pounds it into the ground. It's fairly loud as it hammers these posts, but when he is done, he is done. No need to back fill the posts, or set them in concrete, etc.
He puts in many many cedar posts for his different fenced areas for his horses which he boards.
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ Hydraulic Post Drivers #4
Bulldogger,
I researched the various brands, including the Danuser model, but I chose the Worksaver post driver for its cost and the recommendations of several farmers in the area.
I have put up about 400 posts since April, and I love the machine.
It is a 3 pt. hitch model, with manual adjustments for level. You can look to pay about $1900 - $2200 for one such as mine.
Check out Kencove.com for the 800 number, call them and ask for Charlie.
Good luck.
hess
/ Hydraulic Post Drivers #6
Hey Hess which model worksaver did you get?
/ Hydraulic Post Drivers #7
/ Hydraulic Post Drivers #10
Richard,
I bought the 8' Worksaver (I think it was HD-8), with manual adjustment for level.
hess
/ Hydraulic Post Drivers #11
Hess,
Do you just drop your return hose into the hydraulics fill? I tryed to find an adapter but haven't been able to find one. Also did you ever get your three point and pounder to work at the same time? If not I bought the hpd-20 shc and there is a guy at the factory named Tom that is very knowledgeable on this.
<P ID="edit"><FONT SIZE=-1>Edited by cowboydoc on 09/25/01 10:43 AM (server time).</FONT></P>
/ Hydraulic Post Drivers #12
We have used one with a John deere. It has put in thousands of posts. After a lot of posts the hydraulics would get hot and shut down. It bothered my father-in-law so much he traded the JD for a Ford 3930.
Now a contractor does the fence maintenance.
jrpoux
/ Hydraulic Post Drivers #13
cowboydoc,
No, I had to install a power beyond unit which has a fitting for the return.
As far as the 3 pt. and the pounder working at the same time - well, I spoke with the mechanic at JD and he said that it was unavoidable and he doubted that any re-plumbing would allow them both to work.
If Tom might know a way around this, I'd love any info he might have.
Thanks, hess.
/ Hydraulic Post Drivers #14
Hess,
I think I might have figured out why mine works and yours doesn't. I was pounding posts this weekend and trying to figure it out. On my old post pounder I had a connection to my hydraulics and and a valve to turn off from the pounder to the hydraulics. When I got the new one I used the same one and got the fittings from deere for the new pounder. Do you have the valve that you can either turn to operate the pounder or the 3 point? If not all you need to do is get a valve that will turn off the hydraulics to the pounder. Mine is just like a t-valve and then it has the pounder hydraulic hose hooked to it. I think that will solve your problem. I hooked mine up without it and my 3 point didn't work either. Hooked it back up and it worked fine.
/ Hydraulic Post Drivers #15
The one to avoid is a MULTEC made in northern ireland
They use cheap componants that are mismatched.
The spool valves are not capable of handling the oilflow to allow the weight to fall fast enough to drive in a 5 inch post in less than 15 thumbs in dry earth.
The numpties that make this machine need to understand that a heavy weight is no good without speed
MASS X VELOCITY = FORCE
They also use second hand steel and I dont think they have grasped the concept of Bearings or grease nipples.
worst machine I have ever owned and the company refuse to give any aftersales support so fall into the worst company I have ever dealt with.
A VERY ANGRY CUSTOMER
MULTEC PRODUCTS ARE BEST AVOIDED IN MY OPINION.
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
(5) DRAWER METAL FILING CABINET (A64281)
(5) DRAWER METAL...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
2018 KOMATSU PC238USLC-11 EXCAVATOR (A64279)
2018 KOMATSU...
