Hydraulic problem / questions
   / Hydraulic problem / questions #21
rj,
How long have you had this tractor?
   / Hydraulic problem / questions #22
rj,
   / Hydraulic problem / questions #23
I disconnect the quick connects and join the hoses together, there will be some fluid loss but not much. I keep a bucket handy to catch any loss. Make sure that there is no pressure in the control valve. If yours is like mine I do not think I would mess with the pressure relief valve with out getting all of the possible information before hand. Mine is adjustable and not sure what has to be done to remove mine but if the factory adjustments are changed, I do not know how to reset it to where it should be. Not sure if you have contacted the dealer and talked to their repair guy but this is a good place to start if all else fails. I do it all the time and if they can't help, they tell me who to call to get the information I need.
Good luck.
Farwell
   / Hydraulic problem / questions #24
Good luck.
Farwell
I have had it for about 8 months. Bought it from a private owner and everything was behaving as it was supposed to, etc....
   / Hydraulic problem / questions #27
<font color="blue">Most tractors wil have 2 relief valves. The first is the system relief and it is located near the 3pt. The other is in the loader valve itself. It would be a cartridge that just unscrews.
</font>
Mad,
Do you think I could have a relief valve problem? I have a similar problem has this one I posted here:Loader Problem
I beleive I found and checked the relief valve on the manifold block, but I have figured out where it might be on the control valve. The CV is a Diesel Kiki that I cannot locate any info for.
Thanks!
   / Hydraulic problem / questions #28
</font>
Mad,
Thanks!
I was able to figure out where the relief valve was located- removed it and looked at the internal aspects of it. No blockages, etc.....
Did pay a little more attention to what is going on regarding the problem:
-curl up is unable to lift a load and is slow without a load
-upward movement of the entire bucket with a load does not move easily, while without a load it is fine
I am thinking that the pump will have to be removed and taken in for evaluation. Any other suggestions that I should try?
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2016 John Deere 326E (A47477)
2016 John Deere...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
