Hydraulic Spool Valve Sticking
   / Hydraulic Spool Valve Sticking
And the answer was ?
If you are asking what was found as a cause that is still the not so great unknown. Still doing it (sticking that is) but I have not yet rebuilt the SCV.that is last resort.
   / Hydraulic Spool Valve Sticking #15
Remove the lever for the sticky spool, and rotate the spool 180 degrees.
or
Remove the spool from the bore and inspect, clean.
   / Hydraulic Spool Valve Sticking #16
I did that to mine, referred to in post#8, and it had no effect. :confused: ... Does the lever conventionally drive the spool directly? And is the spool a single piece - no swivel in the middle?
The only explanation I could think of when turning it had no effect was that I wasnt really turning the valving part. :confused3:
   / Hydraulic Spool Valve Sticking #17
By turning the spool 180 or removing it for inspection you might get rid of or see the cause of the sticky problem.
While the spool is out ,check the spool centering springs.
2013 Jeep Wrangler 4x4 SUV (A55853)
2013 Jeep Wrangler...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
