Hydraulic Spool Valve Sticking
   / Hydraulic Spool Valve Sticking
And the answer was ?
If you are asking what was found as a cause that is still the not so great unknown. Still doing it (sticking that is) but I have not yet rebuilt the SCV.that is last resort.
   / Hydraulic Spool Valve Sticking #15
Remove the lever for the sticky spool, and rotate the spool 180 degrees.
or
Remove the spool from the bore and inspect, clean.
   / Hydraulic Spool Valve Sticking #16
I did that to mine, referred to in post#8, and it had no effect. :confused: ... Does the lever conventionally drive the spool directly? And is the spool a single piece - no swivel in the middle?
The only explanation I could think of when turning it had no effect was that I wasnt really turning the valving part. :confused3:
   / Hydraulic Spool Valve Sticking #17
By turning the spool 180 or removing it for inspection you might get rid of or see the cause of the sticky problem.
While the spool is out ,check the spool centering springs.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Year: 2002 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 425,158 Plate: Body Type: 4 (A55852)
Year: 2002 Make...
Cushman Cart (A55853)
19088 (A55758)
19088 (A55758)
Informational Lot - Shipping (A57024)
Informational Lot...
2021 CASE IH Steiger 540 AFS Connect QuadTrac Tractor (A53485)
2021 CASE IH...
