Hydraulic Top Link came apart... Failed!
   / Hydraulic Top Link came apart... Failed! #1
teg
Super Member
nowhere
s
I was actually heading back to the house to sharpen the blades under my mower deck when the tail wheel slammed to the ground. Glad I'm not having to post this in the safety forum (no one ever looks there!!).
So, is this just a matter of unscrewing the top and removing in order until I get to the "Nut" of the problem??
I assume I can not just stick the rod in and spin it until it catches... the nut needs to be tighten
How tight do I put the nut back on? Should I use Loctite when I reassemble?
View attachment 477427View attachment 477428View attachment 477429
   / Hydraulic Top Link came apart... Failed! #2
Yeah, you'll have to disassemble the cylinder and reinstall the piston and nut. I don't know the specs on your cylinder but the nut should be installed with an impact wrench. Who's the maker of the cylinder? That should never happen. Check the threads on the rod and nut to make sure they're not stripped.
If you don't have the means to hold the rod and tighten the nut, remove the cylinder and take it to a hydraulic shop. You can ruin the rod if you score it trying to hold it while tightening the nut.
I was thinking I can clamp the Eye (very end). There is a slight damage to the threads, not sure if it's a problem (or if it might help hold the nut on). First 3 threads are mashed a little.
I honestly can not remember where I got the Top Link.... my guess, it was used and from someone off of Tractorbynet. (chit happens, I'm not worried about it but don't want to have it happen again).
I'm planning to fix it myself. So loctite and hydraulic oil??? No go? or go for it? (blue, most likely)
forgot attachment... :p
PS. just before this happened, I noticed the piston was not straight so I did turn it a 1/4 turn to be straight.
   / Hydraulic Top Link came apart... Failed! #4
Loctite will help but the mating parts need to be cleaned of all oil first. (lacquer thinner, brake cleaner, etc.) Once cured, it's oil resistant.
Use a thread file to clean-up the starting thread. Be sure not to cross thread.
Will do, thanks...
PS. Not to change subjects but I Hate to admit that I've been under this mower (more than a few times) sharpening the blades... Will have to support it from now on.
   / Hydraulic Top Link came apart... Failed! #6
Loctite 545 or Permatex 54540.. Made to work with hydraulic oils and not contaminate it.. Though, if I could, I would drill and tap for a flush set screw.
   / Hydraulic Top Link came apart... Failed! #7
That unit came from Europe and is sold by many retailers. You can hold the rod using some wood in a vise. Clean everything up, I would have thought that there would have been a lock nut, but I guess not, use Loctite (I use red #569) and if you don't have an impact to use, then smack the wrench with a hammer once the nut is tight to give it that last little extra to really tighten it up.
   / Hydraulic Top Link came apart... Failed! #8
@Brian...I think I have the same cylinder...do you by chance know the size or # of the (rod end) end cap o-ring?
   / Hydraulic Top Link came apart... Failed! #9
Yikes. I know you're planning to fix it yourself, but I'd at least take in in to a local hydraulic shop and let them have a look in person and give you a quote. They may see something we can't from picks. Looks like there are several down your way. The female threads may be damaged in the piston, and even if not, the gland seal should probably be replaced after what happened to assure no leaks. Rebuilding it now may not run you much. Even if you end up doing it yourself, doubt you'll know what parts to order without knowing more about the make. A shop would probably know what would fit off the bat.
Let us know how this turns out. Odd how it just let go like that. I've heard of this happening transporting a very heavy rotary cutter too fast over rough ground, when it got to bouncing up and down. Doesn't sound like you were doing that though!
Whoops, just noticed Brian's post. Brian knows!
   / Hydraulic Top Link came apart... Failed! #10
Sorry, never even seen one of them in person that I can think of. Was it leaking before? Unless it got damaged somehow, I wouldn't worry about it, but then that's just me. Easy fix (for me) if there is a problem.
Sorry that I can't help out more. :(
2010 Ford F-350 Ext. Cab RKI Service Truck (A45336)
2010 Ford F-350...
2007 GMC C4500, Cab and Chassis, 4x4, Duramax (A47371)
2007 GMC C4500...
Tong De-Stoner Bucket Stand (A47369)
Tong De-Stoner...
1988 FORD CAB-OVER BOX TRUCK (A45677)
1988 FORD CAB-OVER...
Club Car (A46684)
Club Car (A46684)
2015 Chevrolet Tahoe LS SUV (A46684)
2015 Chevrolet...
