hydraulic top-link
   / hydraulic top-link #11
I agree that float for the top link would be useful when using a rotary brush cutter (aka brushhog). Although the terrain I mow is hilly, I don't need the top link to float as the rear of my mower is supported up to the top link via a chain, which naturally has built in float.
Still don't know of any specific instances where tilt float might be useful - but I'm ready to learn. I have a hydraulic tilt cylinder that adjusts to tilt the box scrapper to either side. Like most small tractors, the 3 point doesn't have down force and so provides float to both sides of the box scraper, tilted or no, when the lever is in the down position.
   / hydraulic top-link #12
My Bush Hog (branded) has plenty of upper link movement built into it where a floating top link would have no valve. I too wonder what a top link float would be used for.
   / hydraulic top-link #13
I am trying to understand this too. My 3 point (B21) has a valve under the seat that adjusts drop rate. Closed all the way it locks the 3 point. Open all the way, the 3 point goes up with no resistance at all. I use that setting for bush hogging and raking. I haven't been able to figure out what the float in a hydraulic top link would do different from that.
   / hydraulic top-link #14
I have plenty of customers that have mowers that do not move enough to allow the mower to move enough forward and backwards to follow their rough terrain, banks along ponds, hillsides etc.
As far as float on the 3pt lower arms, yes both arms will move up and down TOGETHER. Having float on the side link allows for that floating action to be independent of each other. Where or why would a person want that you are thinking. When doing a final smoothing action of a road is a perfect example. Especially at an intersection where the camber of the road changes as you go around the corner. You want the implement to follow the ground contour, not the tractor as it goes around the corner. Other wise you would either be digging in or leaving material. With the implement following the surface, you have neither, you get a firm smooth surface. I do this all the time at the several intersections of roads-drives that I maintain. Others use this feature when using a landscape rake over rough terrain. They are not looking or even wanting to flatten the surface out, just want to clean it up. Having and using the float function with a hydraulic side link allows this to happen.
There are a couple of examples. ;)
   / hydraulic top-link #15
Float function with a hydraulic top link allows the tail of the mower to move UP & DOWN. Believe it or not, all mowers do not have the swivel hitch mount and there are people that even with that swivel hitch mount, the mower does not move enough to allow the mower to follow the ground that they happen to be mowing.;)
   / hydraulic top-link #17
Brian, sounds like float function at the rear remotes is good to have, especially with a mower. But am I wrong in thinking that to have the hydraulic top and sidelinks float, the remote valves themselves must have float capability? I'm thinking that a lot of factory-installed rear remotes do not.
   / hydraulic top-link #18
My LandPride has a flex link on top too, & I still use float. I've thought about removing the hinged link for easier hitching with the quick hitch. I normally leave the top in float for contour following. However its dam nice to kick it out of float & carry the mower just off the ground &back over a ditch or what not with things level. You've already seen the extra lift you can get with the top link to service the underside of the mower (tractor off & put "jack stands" under there first please)
No use for the side link while using a 3pt rotary cutter I've found. It would just let one side drag unless you fabbed up some front gauge wheels (thought about that, but probably not worth the effort). Its still useful for hitching, I can capture the bottom pins on the quick hitch without getting off no matter how crooked I left the cutter sitting. The flex link messes that up for the top link on the rotary cutter though.
   / hydraulic top-link #19
Yes, the valves themselves have to have the float function. Unfortunately you are correct in that at least half or the OEM remotes do not even have the option of having the float function and then a lot of the others have it as an option and since the majority of people have no idea what, why or where the float function would be used, they simply do not get it.
It comes down to education, for the consumer, for the dealer and for the manufacturers. It's a long road to go before the majority truly understand. ;)
   / hydraulic top-link #20
Brian,
Okay, thanks for the explanation of when tilt float would be used. You are correct, when I ordered my Kubota I had the option of getting float for the rear remotes - - and had no clue what that might be used for, didn't have float on a previous TnT, so simply didn't order float - a low cost addition too (rare when buying a new tractor!).
If that oversight ever became critical, one could add it by connecting cylinder ports with a valve between.
bumper
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
1999 Toyota Avalon Sedan (A50324)
1999 Toyota Avalon...
2014 John Deere 6125M (A50120)
2014 John Deere...
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
