Hydraulic valve: Which one?
   / Hydraulic valve: Which one? #1
MicroRacer
Mulhall, Oklahoma
Mahindra 2555
Need a 3 spool valve for my mahindra 2555. 2 of the spools will be used for a T&T and the 3rd will be a second remote hook up. I would like to have 1 of the spools be able to float to use on my tilt cylinder. I looked around for a while and just wound up really confused so I thought I would ask for some advice and see what you guys would recommend for this setup.
Thanks
   / Hydraulic valve: Which one? #2
I recommend you get these. Very good valves and you can get what you need. I highly recommend that you get both of your T&T valves with the float feature. Then the 3rd just a spring return to center valve for most implement cylinders.
If you want, I can set you up with the valves and couplers.
   / Hydraulic valve: Which one? #3
I to am looking to add rear remotes to my tractor a mahindra 2538, just would like 2 spool for a top and tilt kit though,
What would be a good valve for that and I was thinking possibly a joystick valve because they seem to have a smaller valve body, and also where is the connection block from in the picture, it looks nice and clean and ready to bolt on, thanks
   / Hydraulic valve: Which one? #4
The joystick control adds quite a bit to a set of stacking valves, actually to any valve. Plus it can complicate with how the valve gets mounted.
On the pictured valve, the inlet is on the left with a 90 & a 45 pointed to the right. The return to tank port has a 90 pointed to the right and the power beyond is at the center on the right side with the 90 & 45 on it.
   / Hydraulic valve: Which one? #5
This begs a question. I had in the past when inserting a valve in the power beyond circuit, I always ran a separate hose to a T in the existing tank hose. So the hoses on the inserted valve were:
In from last power beyond
Out on PBY to In on next valve
To Tank
(2) Cylinders Work Ports
Then I was looking at my backhoe and there are only two hoses. One from FEL power beyond and one returning to the tractor. No third hose.
When do I need a 3rd (Tank) hose? Does the last valve not need one because everything goes to tank at that point?
   / Hydraulic valve: Which one? #6
To Tank
Correct, the last valve dumps all fluid back to the tank.
   / Hydraulic valve: Which one? #7
OK, now I have a question while on this hydraulic valve discussion with knowledgeable people.
I am looking at ordering a new CUT with two rear remote valves. One to control the angle of a back blade and another remote valve, just incase I would find a need for it in the future.
Would a "return to center valve" be good for angling the back blade?
I was thinking of ordering (1) "return to center" and (1) with a "float" position. Would this be a wise choice? I will not be going with a top & tilt configuration.
   / Hydraulic valve: Which one? #8
I have 3 remotes on the rear of my tractor, 2 are spring centered and 1 is detented, none of them have a float position and I have missed that function several times.
If I could have gotten a float I would have. I like float for floating on two way cylinders and its really nice to have on single acting cylinders which many implements have.
I like detent valves for anything that's has it's own control such as a wood splitter or a hydraulic motor such as grain or fertilizer carts.
A spring to center would be a good valve for angling a blade, also its hard to have to many remotes.
enjoy
   / Hydraulic valve: Which one? #9
I don't know the size tractor or blade you are considering but you could be short changing yourself with just 2 remotes, many blades that have a hydraulic angle could also have hydraulic tilt and hydraulic offset then add a hydraulic top link and you are up to 4 remotes.
Luck
   / Hydraulic valve: Which one? #10
A float feature valve works just like a spring return to center valve. (let go of the lever and valve springs back into the closed position) It just has that 4th detent position which has the float mode feature.
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
240156 (A56859)
240156 (A56859)
CAT 930M (A58214)
CAT 930M (A58214)
Adams Tilt Trailer (A56436)
Adams Tilt Trailer...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
