Hydraulic Winch installation Kubota L2950
   / Hydraulic Winch installation Kubota L2950 #21
Cytafex, I have just come across this thread and one thing that concerns me is the winch that you are wanting to use.If it is a Warn winch or similar you can not dead pull (using the tractor to pull without the winch rotating) as it will damage the brake I have had this problem with the 12000lb winch on my machine. the brake is located between the drive motor and the planetary gearbox,inside the drum:2cents:
Hey Tony,
I have a Mile Marker 12,000 lb pull that was made for the military (our tax $ going to work for me) that is bolted to a hitch on the 3 point. I haven't been pulling from the winch, but a clevis hook on the hitch. Thanks for the heads up anyway.
1036 (A51572)
1036 (A51572)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2007 DOOSAN G80 GENERATOR (A52472)
2007 DOOSAN G80...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
