Hydraulics are weak.
   / Hydraulics are weak. #11
What kind of backhoe is it? Sounds like a leakdown problem to me? Change the factory fluid and filters and keep the rpm's up for best hydraulic performance.
   / Hydraulics are weak. #12
   / Hydraulics are weak. #13
Farm trac says 1st change at 120hrs?? most others say 50hrs.
Could be your filters. stretching in the morning sounds like the time it takes for the pump to build up enough pressure could be a clog.Make sure to clean that not to easy to reach metal screen filter.
When I dig I run about 1500rpm-2000rpm.
   / Hydraulics are weak. #14
They recommended a filter change at 50 hours. (Did that one.) then the full change at 100 hours. But since the tractor was in heavy use at the time. I called the dealer and he said to get the stuff ordered and change it before 120 hours. (I'm at 119.4 so I did push that a bit more than I probably should have. Just wanted to finish digging the ditches before the rain won!). The backhoe and loader is Farmtrac branded but I'm not sure who makes it for them.
   / Hydraulics are weak. #17
Overnight is not really fast for a leak down, and it quite common on many hydraulic machines. I'm surprised that before you were able to have it stay up for a MONTH.
I have my backhoe down when it's on the tractor not being used, but it will leak down at least half way overnight if I leave it up without the boom lock in place. I don't find that unusual.
Don't worry that you waited a while on the fluid change, it was not that critical, but should be done now that you're near the 120 hours.
John
   / Hydraulics are weak. #18
John
   / Hydraulics are weak. #19
Is what you are calling "weak" , the increasing rate of leakdown in the cylinders when not being used ?
Ben
   / Hydraulics are weak. #20
Ben
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
METAL SHOP TABLE W/CONTENTS (A55745)
METAL SHOP TABLE...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
