Hydraulics Mystery...
   / Hydraulics Mystery...
Thanks for the suggestions! 3 more quick questions:
  1. What if the fitting is not PB (i.e. just reducer)? Is this a big problem?
  2. Is it worth swapping out the OUT hose with a larger size to match the IN? Would this materially improve the FEL performance?
  3. I want to check the fluid for aeration. But to see into the reservoir I must remove the filter. Is it OK to run my hydraulics for a few minutes with the filter removed?
I'll post back after I figure out the correct fix. I bought a PSI gauge today and I'll test pressures tomorrow. Thanks!
   / Hydraulics Mystery... #12
#1 you would not have high psi after that valve. #2 Wait on that, but yes it should speed it up and help hold down heat. #3 I would not do that if you are talking hyd filter.
   / Hydraulics Mystery... #13
"What Leejohn said." ^^ btw, 3 line/fitting sizes, or optical illusion? Tractor has 12 GPM pump flow, yes?.
I'll risk any backlash by suggesting 1/2" min lines/fittings for 12 GPM and 3/8" only for 6 GPM valves/use.
Also, I beg you to replace malleable iron street 90s (what they look like, .. 300 PSI or less max) or they will fail in time at >2k PSI.
Be sure "PB" and "return to tank" (pic #2) aren't reversed. (?) May help to plumb up some 'adapters' beforehand to ease gauge connection at various points in the system, including QDs to test FEL lines etc.
   / Hydraulics Mystery... #14
i have a massey ferguson 451 with shuttle shift and for some reason the hydraulic system seems to stop working i clean the filter an its full of sludge an replace it and happens again any way to flush the system i cant get more then 15 to 20 minutes out of the new filter ?
   / Hydraulics Mystery... #15
I have a farmtrac 360 the loader and 3 point hitch and remote values stop working. Was wondering if it could be the filter or did the pump just stop working?
2011 Nissan Maxima Sedan (A55758)
2011 Nissan Maxima...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55302)
2-Row Peanut...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
