hydraulics on b-hoe attachmnt shut down
   / hydraulics on b-hoe attachmnt shut down #21
BINGO!! That's what my neighbour said aswell (he built this attachment). It was connected with a U-joint, one side to the PTO, and one side to the pump shaft. the pump shaft is much harder and stripped out the inside of the u-joint splines. Way better than needing a pump!!:thumbsup::D
so now I need to find a yoke with 13 splines. Any suggestions on where I find a U-joint yoke to match?
Check the fit of the splines on the pump also.....if you can drill for a grease fitting on the new u-joint spline it will help .....
7/8-13 spline is common.......if it's a Vickers pump then a new shaft and seal kit will be a perfect fix....Easy to fix......
Glad you found it....:thumbsup:
the shaft is a harder steel and seems fine. my neighbour also told me to grease the splines. When I mentioned that to the local tractor parts dealer, they didn't think grease on the splines would help a lot. I know it can't hurt.
thanks for the heads up wdchyd.
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
2013 VW Tiguan SUV (A56859)
2013 VW Tiguan SUV...
