hydraulics on b-hoe attachmnt shut down
   / hydraulics on b-hoe attachmnt shut down #21
BINGO!! That's what my neighbour said aswell (he built this attachment). It was connected with a U-joint, one side to the PTO, and one side to the pump shaft. the pump shaft is much harder and stripped out the inside of the u-joint splines. Way better than needing a pump!!:thumbsup::D
so now I need to find a yoke with 13 splines. Any suggestions on where I find a U-joint yoke to match?
Check the fit of the splines on the pump also.....if you can drill for a grease fitting on the new u-joint spline it will help .....
7/8-13 spline is common.......if it's a Vickers pump then a new shaft and seal kit will be a perfect fix....Easy to fix......
Glad you found it....:thumbsup:
the shaft is a harder steel and seems fine. my neighbour also told me to grease the splines. When I mentioned that to the local tractor parts dealer, they didn't think grease on the splines would help a lot. I know it can't hurt.
thanks for the heads up wdchyd.
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
108 (A52708)
108 (A52708)
2003 Sea Ray SLX 29' (A56859)
2003 Sea Ray SLX...
