Hydrolic screen
/ Hydrolic screen #1
texoak51
owasso,ok
kubota m6800dt
I have read several times to check the hydrolic screen and filters when hydrolics are slow. Where is the hydrolic screen located on 2002 kubota m6800 . Also the boot around my fel joystick has developed a hole and is greasy. Why would there be grease in this area. Thanks
/ Hydrolic screen #2
I'd suggest you view Kubota parts online or have Messicks email you the parts schematics for hyd system to determine if M6800 has a hyd sump screen.
/ Hydrolic screen
Thanks, Jim. I looked it up kubota parts as you suggested and it appears the 6800 does not have a separate screen except a magnetic one at the hydrolic filters. That site also helped answer some other questions as far as locations and routing. Thanks again
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
