Hydrostatic ATV
   / Hydrostatic ATV #121
How about "Liberty Ship" as it gives you the freedom to go off road?
Did you model the tires, or were they available from a manufacturer's web site.
   / Hydrostatic ATV
   / Hydrostatic ATV
I am starting the frame and am wondering if 1/8 wall 2x2 square tubing is thick enough or even to thick. What are your thoughts on that.
   / Hydrostatic ATV #125
Did you run Inventor's stress analysis routines? I'm not skilled enough with the software to know how to work that part of the program yet.
Gut feeling is that 1/8" thick is the bare minimum, and 3/16" the maximum. Though I think 3/16" would be overkill. Mind you that's a guess.
   / Hydrostatic ATV #126
The area around the articulation joint and those parts I would do out of 3/16" wall . There is going to be a tremendous amount of force from different angles that the structure needs to deal with.
The rest of the structure I would use 1/8" and double up in areas of higher stress.
   / Hydrostatic ATV
Yes I have played around with the stress analysis but not that confident with it.
I planned on making the joint area heavier than the rest. Your right that it will need to be strong. If that fails I'm screwed. It defiantly the most important part of the machine.
   / Hydrostatic ATV #129
I haven't read through 13+ pages but the solution has undoubtedly been mentioned. Just bolt on four wheel motors from a zero turn mower onto an old 2WD ATV. Tuff Torq lists the specs on their web site.
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2019 Allmand Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
