Hypro pump
/ Hypro pump #1
jpmgary
Dawson,Tx
856 IH
I have a 6500cr pump driven by a direct drive 5hp Honda gas motor with a speed reducer. I am having problems with not getting much pressure 10-20 # only. I have checked for restrictions on the suction side but found none. What do you think could be the problem? I purchased the counter rotation pump because the gas motor runs opposite rotation of my pto on the tractor.
/ Hypro pump #2
Is there a filter somewhere that could cause a restriction? Are you sure the pump is turning the right direction? Is the engine turning the right RPM? Just wild guesses.
You say you bought a counter rotation pump because the gas motor runs opposite rotation of the tractor PTO. I used to have a spray rig powered by an old 3 hp Briggs, and had the same situation. But you can also just take the pump apart and put it back together to turn the other direction.
2018 Deere 50G (A64126)
2018 Deere 50G...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
