OP
DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,601
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I made jibs to lift the beam. Space was limited, so had to do some pretty close calculations. I used double dogged 2 ton come-a-longs to winch it up there. With the space I had to work with, I had to take the hooks of the end of the cables, and ran the cable through an 11/16" hole, with a thimble in there to keep from cutting the cable, in some lifting brackets I made. I used the ole' IH 656 on the right, and Massey 180 on the left for boat anchors, pulling off the drawbars. I added some hook points, for pennant lines, to keep the pull off the uprights. Just got the cables taught on the smaller come-a-longs.
Took about 45 minutes to winch it up there by myself..., and that was taking a break about half way up to get a drink, and look things over... 10 clicks = 6" of lift. Look at the picture closely, and you will see just how much lift I had left... Didn't need it,as the beam was in place when this picture was taken. I figured the distance on the lifting rigging, so as the beam would swing in, and be on center. I did have to take a bar clamp,and scoonch it 1/2" to be OC., and 3/8" longways to be OC there too... Not bad for an ole' dumb country boy..., LOL...
