I broke the law... a lot!
   / I broke the law... a lot! #31
A friend of mine in CA. Went to the dump with his loaded dump trailer, and on that day the CHP happened to be at the scales writing tickets for over weight loads. His trailer is a 7 x 14 W/ 4ft sides 14k gross weight. They had him weight just the axle part of the trailer it came in at 18,000 lbs. the cop gave him a choice, of his ticket, not having a class "A" license for being over 10k lbs. Or for being over the gross of the trailer. Another thing about CA is that any size pick-up is registered as commerical. Bumper pull travel trailers and fifth wheels camper trailers do not fall under the 10k law.:D
   / I broke the law... a lot! #32
After reading this and similar threads, all I can say is "aren't we all glad there are lawyers?" (NOT). The federal regs seem pretty clear and straightforward and most states copy them verbatim BUT they do not interpret them identically. Worse yet, the ultimate test is what the officer with the badge and gun says -- because that's what will affect you TODAY. My Daddy taught me, "Never argue with the man with a hammer." And he meant sledge, framing, 9mm, or .38 caliber.
I think the composite advice is: a) Consult your local DMV AND b) consult the local commercial officer(s).
VistanTN
Who's wondering where the new 2500HD and the Good Wyfe's plan for a gooseneck horse trailer will put us ...
   / I broke the law... a lot! #33
From the Washington State Department of Licensing:
Types of vehicles requiring a CDL
You must get a commercial driver license (CDL) to operate the following types of vehicles:
All single vehicles with a manufacturer's weight rating of 26,001 pounds or more.
All trailers with a manufacturer's weight rating of 10,001 pounds or more, if the gross weight rating of the combined vehicle(s) is 26,001 pounds or higher.
All vehicles designed to transport 16 or more persons (including the driver).
All vehicles that carry hazardous materials.
Notice the second qualifier, "10,001 pounds or more, IF the gross weight rating of the combined vehicle(s) is 26,001 pounds or higher.
Now the part that does not make since to me is with my 12,000 GVW dually I can only have a 14,000 pound rated trailer. But if I have a 10,000 GVW rated single axle 1-ton or 3/4 ton truck I can have a 16,000 pound rated trailer. This does not seem right to me.
steve
   / I broke the law... a lot! #34
steve
This is interesting. I looked at a gooseneck Dump trailer with a 16400 GVWR, but combined with my 1 ton Dodge (11000) GVWR puts the combo at 27400.
I had to buy the 14,000 dumper instead. But if I pulled the same trailer with a 1/2 ton pickup or Toyota, its ok? This is dumb or maybe they don't make a gooseneck in bed ball hitch for small trucks?
It has to be more dangerous....good point indeed. You'd think there would have to be some kind of balance in the law, not just a weight or combined weight. The bigger the pickup, less you can trailer, smaller the pickup, more weight you can tow.....doesn't seem right to me either.
Steve
   / I broke the law... a lot! #36
steve
Read post number 20 in the thread " I almost broke the law...alot". This should clear things up for you.
   / I broke the law... a lot! #37
Steve
Read post number 20 in " I almost broke the law...alot" to see how you don't add the tow vehicle and the trailers rating to get your limit.
   / I broke the law... a lot! #38
From the license standpoint...you only have to have a CDL if you fall under these guidelines, from the FMCSA. The part about the 10K trailer gets confusing depending on whose version you hear or read. This pretty much states it as is, and is written by the people who make the laws.
David from jax
The Federal standard requires States to issue a CDL to drivers according to the following license classifications:
Class A -- Any combination of vehicles with a GVWR of 26,001 or more pounds provided the GVWR of the vehicle(s) being towed is in excess of 10,000 pounds.
Class B -- Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
Class C -- Any single vehicle, or combination of vehicles, that does not meet the definition of Class A or Class B, but is either designed to transport 16 or more passengers, including the driver, or is placarded for hazardous materials.
   / I broke the law... a lot! #39
I too was worried about this and thought along the lines of over 10,000# or combination over 26,000#. BUT happily here in the great state of CheeseConsin, I can have a 6000# truck and a 20,000# trailer and NOT need a CDL, a 26,000# truck and an 8000# trailer and NOT need a CDL, a 20,000# truck and an 8000# trailer and NOT need a CDL. These examples are posted on the wisconsin dot web site in a PDF titled "cdl-vol1.pdf".
The keys are if the trailer is over 10,000# AND the total combination is over 26,000#. If the Trailer is UNDER 10,000# and the truck is at 26,000# you are just barely ok. I guess WI is going by the Fed law and not tighter. I do feel sorry for you guys in tougher states, especially the peoples republic of California. Seems crazy strict to me!
jb
   / I broke the law... a lot! #40
jb
I see the chart you are getting that info from. I would be very leary of that. It doesnt meet federal standards and doesnt match what they say here: Commercial driver license (CDL) - Wisconsin Department of Transportation or herehttp://www.dot.wisconsin.gov/drivers/docs/cdl-vol1.pdf, which is a couple pages below that chart.:
You must have a CDL to operate:
• Any single vehicle with a gross vehicle weight rating
(GVWR), actual weight, or registered weight over
26,000 lbs. or such vehicle towing a vehicle with a
GVWR, actual weight, or registered weight of 10,000
lbs. or less.
• Any combination of vehicles with a gross vehicle
weight rating (GVWR), actual weight, or registered
weight over 26,000 lbs. provided the GVWR, actual
weight, or registered weight of the towed vehicle(s)
is more than 10,000 lbs.
I think someone in WI government has a reading comprehension problem. Maybe they have their manuals printed in china or something. Here is why the chart can not be right.
"COMMERCIAL MOTOR VEHICLE SAFETY ACT OF 1986
The Act retained the State's right to issue a driver's license, but established minimum national standards which States must meet when licensing CMV drivers.
It is important to note that the Act does not require drivers to obtain a separate Federal license; it merely requires States to upgrade their existing testing and licensing programs, if necessary, to conform with the Federal minimum standards"
Here is the applicable federal standard:
"Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in commerce to transport passengers or property if the motor vehicle-
(a) Has a gross combination weight rating of 11,794 kilograms or more (26,001 pounds or more) inclusive of a towed unit(s) with a gross vehicle weight rating of more than 4,536 kilograms (10,000 pounds); or
(b) Has a gross vehicle weight rating of 11,794 or more kilograms (26,001 pounds or more);"
2005 Gravely 260Z 60in Zero Turn Commercial Mower (A55787)
2005 Gravely 260Z...
378915 (A54865)
378915 (A54865)
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
1000 Gallon 6 Lug Water Wagon (A50775)
1000 Gallon 6 Lug...
KJ Portable Restroom (A53316)
KJ Portable...
