I cracked my valve cover...
/ I cracked my valve cover... #1
RADIATION
Kioti LK3054
Hello All,
I'm new to tractors. I bought a kioti lk3054 with a head gasket problem. HG had been replaced but tractor still ran like garbage and bubbled radiator. I tore the head off and they head used the wrong gasket. I put the right one on and put it back together using the LK30 manual i got from this forum. Everything was great and running great until i decided to follow the manual and retorque the gasket. I retorqued and was putting everything back together and decided i better torque the valve cover to be precise. I ignored my gut and heard a faint tink... took the cover off again and 2 out of 3 bolt holes have a faint 3 spider crack... :mad:
I put it back together and just snugged the bolts. I ran it up to normal temp and there's no oil coming out of bottom of cover or anywhere else for that matter. I'd still like to replace it. Does anyone have one?
/ I cracked my valve cover... #2
I might have one. We need to verify it is the same. I have the original engine from my 2554 that slung a rod. The head is fine but not sure the difference between the two engines. Maybe we could check part numbers. I will check it out.
What version 3054 do you have?
The part number for the one I have is E5500-14505. It is the old style.
This is the one i have, thank you for your response!
/ I cracked my valve cover... #4
I believe you might be in luck. Can you read the plate on your engine? Is it a TD1300 or TD1400?
/ I cracked my valve cover... #5
Also mine is pre law suit, so it is blue in color if that matters to you.
/ I cracked my valve cover... #6
Here is a picture.
Yes sir that's the one, and i don't know where said plate is on the engine, I've hunted it over and only found an embossed 1395cc.
Here Is a picture of mine. How much are you asking sir?
/ I cracked my valve cover... #8
I will make you a deal. PM me your address and I will take it off, then send it to you. Once you get it fixed post a picture and we will call it even. If you do not use it, send it back so it will be available for whoever else might need it. Does that sound like a deal?
PM sent! Thank you so much!
/ I cracked my valve cover... #10
My pleasure and welcome to TBN!
/ I cracked my valve cover... #11
Manage to find some time this afternoon to get your valve cover off. I will get it boxed up tomorrow and shipped. I will PM you the tracking number tomorrow night.
I wiped it off, but you will need to clean and paint if you so desire. :drink:
/ I cracked my valve cover... #12
Shipped USPS and should be there Friday. I sent you the tracking # in a PM. Good luck!
/ I cracked my valve cover... #14
That's what makes this site great. Members like K5lwq helping others with anything from good advise to free parts! Way to go K5!
/ I cracked my valve cover... #15
Hams are generous folks. They know what is is like to have to scrounge around for a hard to find part.
Thanks for helping this fella out... 73 James KØUA
Thank you again
/ I cracked my valve cover... #17
Thanks guys for the kind remarks and Radiation you are more than welcome. I hate to throw things away until all useful parts are used. My wife wishes I did not have this problem but I like my junk. This helps me prove to her the value of keeping things. I have had many opportunities to help folks that needed stuff and got myself out of a few jams... 73
/ I cracked my valve cover... #18
Posts like this one clearly demonstrate the moral character of tractor people. Same sort of thing I experienced at the track as a kid racing motocross. Parts and know how where continually passed from one team / family to another.
I recieved cover today! Your packaging was excellent! I will try to get it put on tomorrow and I'll post up a picture! Thank you again!
/ I cracked my valve cover... #20
Glad it made it in one piece. I tend to go overboard with packing. Also have had less damage from USPS than UPS and FEDEX. Not sure how those guys can beat a package up so bad. :thumbsup:
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
(2) TW 30 FORD WHEELS (A60432)
(2) TW 30 FORD...
2019 Ford F-150 Pickup Truck (A59230)
2019 Ford F-150...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
