Buying Advice I Hate Trips to the Dealer...
   / I Hate Trips to the Dealer... #11
Robert,
For 27 years I had a rear mount, 3-point, snow blower. I have a mile long gravel driveway, yard & large mail box area to clear. I normally would clear all these areas with my rear blade. Oh, I had a 1982 Ford 1700 4WD - bought brand new in '82. I ONLY used the blower if and when the frozen berms got so big that I couldn't break them with the rear blade.
Most years I would use the blower maybe two times. However, I got to hating that rear blower so much - in 2009 I upgraded to my current 2009 Kubota M6040. Stiff necks, sore shoulders, having the small pines shower me with snow as I went on by, no matter where you point the chute, the winds brings fine snow/mist back to cover you - now, a thing of the past.
Anyhow - my Kubota as currently set up weighs in at 10,100 pounds and with the 1000 pound Rhino 950 rear blade I clear any and all berms as though they are made of cotton candy.
   / I Hate Trips to the Dealer... #12
My response... look at the list to the left... I'm a Kubota crackhead...:confused3:
I simply can't help myself. I slow down when I pass a Kubota dealer on the road, I drool on the steering wheel... and usually drive off the road rubber necking the whole way.
   / I Hate Trips to the Dealer... #13
   / I Hate Trips to the Dealer... #14
Those front mount snowblowers are the cat's ***. The only reason I would go with a rear mount would be for my 5 series deere to be able to handle the HP.
We have a 7' front mount Loftness on our L3830 that runs off of the rear PTO. It came off of a 60ish HP NH and I would guess that they could set you up with something similar.
I might look into building or buying a hydraulic power pack and putting the blower on the loader.
Aaron Z
   / I Hate Trips to the Dealer... #15
Aaron Z
Does that setup use a power pack or is it shaft driven? I don't really have a need for a snow blower on the 5 series. That's an interesting idea but probably not very cost effective. I have a 10' snow pusher that makes short work of just about everything we get here in PA.
Robert,
An M6040 would be more than overkill for me. For 15 years, I used a rear blade and front end loader. I figured the blower would be the cats meow. I bought it three seasons ago, it's NEVER been used. I was originally thinking when I retired, I would not be interested in freezing my giblets off for hours in a west wind trying to open my drive with a rear blade or loader. Been there. It took me 4-1/2 hours to scoop and pile snow, when I could have blown it away in 45 minutes. Then, it drifts back in. With a blower, the snow is gone.
I think I'll put my blower on Craigs and see if I can sell it this winter. I'll move snow with the loader and gat a rear blade. Then, next summer, I'll order the front blower and QA for my BX2570. I don't need an 80-Series. I'll keep telling myself this and hope it sinks in. I watched the video to see how easy the new 4 point front QA works, and it is way ahead of the old. That would be another reason I'd like an 80. But, how often will the 4-point be used? Hmmmm. Just like my current blower?
   / I Hate Trips to the Dealer... #17
Yea - well maybe the 3-point blower wouldn't be so bad if you had a cab. But, first off - the 3-point blower is slower than cold snot, and without a cab and some heat my neck & shoulders would get so STIFF. I tried Jack Daniels - but I was 3/4 looped before there was any relief from the stiffness - it wasn't a good situation.
With the blower it would take me 3 1/2 to 4 hours to clear the yard, driveway and mailbox area. With my rear blade I'm done in 1 1/2 hours and it been all driving forward. I think you have the answer. A front blower would be a real relief, easy on all the joints that otherwise would get stiff & sore.
   / I Hate Trips to the Dealer... #18
It is shaft driven off of the rear PTO with a pair of gearboxes and 1.5" shafts.
Aaron Z
   / I Hate Trips to the Dealer... #19
Both front tires on the bx2200 were leaking and I just took them to Big-O and had them put tubes in. Maybe you should had went to Big-O's. They don't have nice shiney, pretty, new smelling tractors in the show room. Only tires and rims for sale and maybe a peanut vending machine.
   / I Hate Trips to the Dealer... #20
retirement your suppose to go where its warm and not worry about the snow
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
New/Unused Agrotk Tire Changer (A54865)
New/Unused Agrotk...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55302)
2012 NEW HOLLAND...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
