stumpfield said:This sounds simple but I've googled and searched everywhere but can't find any reference of anyone already tried this. Strange.... I wonder why?
Because you are a genius
Bob
MikeD74T said:Running water does not freeze which is why rivers still flow in winter. MikeD74T
stumpfield said:turnkey4099:
This is exactly what I'm looking for. Thank you! I hope I understood your sugguestion....
I will need to prime or do whatever neccessary to get the pump started to fill the hose full of water to start the siphon process. I would open the bypass valve and shut the pump down and let the siphon process take over. A check valve at the bottom of the pickup hose to prevent water draining back into the well and hopefully keep the pump primed in case I lose siphon and have to do this again (another valve to fill with more water if neccessary). A flow control valve on the discharge side to regulate the flow and keep it under the well's recovery rate to prevent any significant water level drop.
Of course, if I excavate down to reduce the lift, it may be easier to start the siphon and may be more reliable. But at only 2gpm and if I don't lose siphon very often, I may not need to do that.
Thanks again. Here's a sketch:
RonMar said:Why are you using the pump? Am I missing something here, Stumpfield where are you going to put the pump in the system? Centrifigal pumps don't pump air very well and like a shop vacume will certainly not pull enough vacume to lift water very far unless they are full of water. They will only move water and build pressure when they are full of water that CAN'T be compressed or stretched like air. Same reason why hydraulic systems don't work real well when full of air. If you are placing the pump at the top near the well head, you will have to haul enough water to fill the suction side hose and pump completely to make that pump move water and more importantly lift water that far(I have done this particular task a lot onboard ships). That is why that black cap is above the pump body, to prime and get all the air out of the pump(reference operators manual on robin subaru website). Since you will have to prime the system anyway, why not just prime the siphon pipe and let gravity start the flow.
The best Idea I have heard here so far for using this pump was from Alan B. Put the pump at the downhill outlet of the siphon and pump water backward from a tank near the outlet up to the well. Once the line is full and putting water into the well, shutdown the pump. The weight of the water on the outlet will reverse the flow and the siphon will be running. No valves or fittings involved and you can remove the pump at will without breaking the siphon as it will be on the pressurized outlet side of the siphon.
