Re: I have been notified, very politely I might ad
</font><font color="blue" class="small">( Just a note on pesticides. I've been told that boiling is an acceptable way to get rid of these as they are more volatile than water and the boiling will drive them off)</font>
Depends on the design of the still. Often, volatiles will pass right through the still and into the finished water. Solids and bacteria are effectively removed by distillation.
This all points to the first rule of water treatment, find out what you have to treat. In the case at hand, we have the possibility of contaminatioon from livestock waste and possibly pesticides, along with the general run of well water nuisances.
You've got to get a good analysis to find out what's in there, so you know what to be scared about. Often the health dept will do well water quality analyses. If not, an environmental lab can do this, as has already been suggested. That can be the best two hundred bucks you spend.
Hardness is not a worry. The test done by miost water softener companies is for hardness. It's a neat test, as lots of crap precipitates out in the flask. If you have well water, I will bet a beer it's hard. You can use any old water softener to get rid of most hardness.
Iron and manganese are nuisances. Iron tastes bad, and leaves brown stains. Manganese leaves black stains. Neither will hurt you.
Sulfur is a common contaminant. It makes the water stink. It won't hurt you, but it may make the water too nasty to drink.
With livestock on top of a sand aquifer, I'd be concerned about bacteria and nitrates.
Bacteria, as we all know, can make us sick. The Total Coliform and Fecal Coliform tests are the standard ones, but the coli aren't the bad stuff. It's just that if you have fecal coliform, you assume there's also worse things in the water, or may be. You can kill most of the bac with chlorine and remove the chlorine with an activated carbon filter under the sink. But if I had bac contamination, I'd be looking for another drinking water source.
Nitrates have been linked with birth defects in infants. It comes from the urine leaching into the water. It is very soluable and won't filter out with sand. RO will remove nitrates.
Anything with a name you can't pronounce, is reason to ask hard questions. Usually you're looking at pesticides or organic chemicals. RO will take that stuff out, but be certain the particular RO unit you buy will remove those particular contaminants. Activated carbon will remove small quantities, too. Again, I'd be looking for another water source, if I had significant contamination with pesticides or organics.
My nasty water has iron, manganese, and sulfur, and is hard. Right now, I'm looking at building a chlorination plant to oxidise out the Fe, Mn, and S, followed by a sand filter to remove the soilids the oxidation process will generate. Then, I'll put in a carbon filter to get rid of the Cl taste. Maybe I can cob something together over the winter.
