I have "BUSTICATED" my tractor
   / I have "BUSTICATED" my tractor #1
wksinatl
Atlanta
case IH 485
I have \"BUSTICATED\" my tractor
I was bush hogging and noticed one side was a bunch lower than the other. A quick eyeball showed that I have problems. I know my terminology probably isn't right but it looks like I have broken the bottom part of the side link and a link from the adjustable sway bar.
Is this something that TSC would carry?
Any ideas what may have caused this and how to avoid it again?
BTW, I was using my Case 485 and a Rhino 6' rotary cutter.
thanks guys,
Keith
Re: I have \"BUSTICATED\" my tractor
another pic
last one
   / I have "BUSTICATED" my tractor #4
I think your going to have to go to a regular tractor place for that pin, but you should be able to have the eyelet on the lower link welded.
...Tony
   / I have "BUSTICATED" my tractor #5
to me, it looks like there was a lot of side stress that caused the metal to crack. Could the mower hit a stump as you were turning or some other event that would cause some sidewards movement of the implement??????
   / I have "BUSTICATED" my tractor #6
I put 1/4" bolts with locknuts in place of the hairpin clips (hitchpin).
The way I see your break, is a clip slipped out part way, broke the tip off that pin through the clevis, which left just half the clevis holding, and the subsequent twisting load caused a break in that half. Appears the clevis is turned 180° in the picture from failure position, given the 'dirt' location and the break.
Just a guess, as I sure don't know. But, seems it may have started with a hairpin clip getting pulled out.
   / I have "BUSTICATED" my tractor #7
wksinatl
Try Bates for used IH parts. www.batescorp.com They specialize in such and I used them when I owned an IH444.
Vernon
I think I agree with beenthere. It makes perfect sense. junkman, I didn't hit anything (that I remember)
TSC did not have either part. I will try the company suggested by texbaylea.
Thanks for all the help/comments!
Keith
   / I have "BUSTICATED" my tractor #9
You will find items like this at your dealer.
Leo
   / I have "BUSTICATED" my tractor #10
We only broke the pin, twice on the 585 and the 584 we use. It seems to be a weak spot on those models.
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
2011 Lexus RX SUV (A53117)
2011 Lexus RX SUV...
ITEM LOCATION (A53084)
Ford 4630 (A50123)
Ford 4630 (A50123)
Year: 2015 Make: Ford Model: F-750 Vehicle Type: Truck Mileage: 79992 Plate: Body Type: Regular Cab (A51692)
Year: 2015 Make...
