I have "BUSTICATED" my tractor
   / I have "BUSTICATED" my tractor #1
wksinatl
Atlanta
case IH 485
I have \"BUSTICATED\" my tractor
I was bush hogging and noticed one side was a bunch lower than the other. A quick eyeball showed that I have problems. I know my terminology probably isn't right but it looks like I have broken the bottom part of the side link and a link from the adjustable sway bar.
Is this something that TSC would carry?
Any ideas what may have caused this and how to avoid it again?
BTW, I was using my Case 485 and a Rhino 6' rotary cutter.
thanks guys,
Keith
Re: I have \"BUSTICATED\" my tractor
another pic
last one
   / I have "BUSTICATED" my tractor #4
I think your going to have to go to a regular tractor place for that pin, but you should be able to have the eyelet on the lower link welded.
...Tony
   / I have "BUSTICATED" my tractor #5
to me, it looks like there was a lot of side stress that caused the metal to crack. Could the mower hit a stump as you were turning or some other event that would cause some sidewards movement of the implement??????
   / I have "BUSTICATED" my tractor #6
I put 1/4" bolts with locknuts in place of the hairpin clips (hitchpin).
The way I see your break, is a clip slipped out part way, broke the tip off that pin through the clevis, which left just half the clevis holding, and the subsequent twisting load caused a break in that half. Appears the clevis is turned 180° in the picture from failure position, given the 'dirt' location and the break.
Just a guess, as I sure don't know. But, seems it may have started with a hairpin clip getting pulled out.
   / I have "BUSTICATED" my tractor #7
wksinatl
Try Bates for used IH parts. www.batescorp.com They specialize in such and I used them when I owned an IH444.
Vernon
I think I agree with beenthere. It makes perfect sense. junkman, I didn't hit anything (that I remember)
TSC did not have either part. I will try the company suggested by texbaylea.
Thanks for all the help/comments!
Keith
   / I have "BUSTICATED" my tractor #9
You will find items like this at your dealer.
Leo
   / I have "BUSTICATED" my tractor #10
We only broke the pin, twice on the 585 and the 584 we use. It seems to be a weak spot on those models.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
2015 Ford F-350 Dump Truck (A51691)
2015 Ford F-350...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
