I hope Amsoil synthetic ATH was not a waste of $$$
   / I hope Amsoil synthetic ATH was not a waste of $$$ #41
_RaT_ said:
The last time I saw all the specifications on SUDT and Amsoil, the SUDT had better specifications all the way around. Especially true of the cold weather ability. So if having a synthetic is what is most important, then check into Amsoil, Chevron etc., all synthetic but if having the better product specifications is more important, the SUDT was the last time I saw the figures, superior. Things may have changed.
I can't seem to find any references to the SUDT's specs anywhere. Anyone else know what they are?
   / I hope Amsoil synthetic ATH was not a waste of $$$ #42
My thing on synthetic is best described in this quote: "It's the difference between baking a cake (putting in only the things you want) and trying to boil, manipulate, and additize raw sewage until you come up with birthday cake."
I am trying to figure out what extended interval I can use when I switch to Amsoil ATH. Manual says 300 hours with SUDT or UDT. In my other vehicles I can go for about 3+ times the regular change interval, but I want Amsoil of someone in the know to tell me I can run the ATH for 900 hours before I actually do it.
Chris
   / I hope Amsoil synthetic ATH was not a waste of $$$ #43
Was AMSoil started by Amway? Same marketing approach. Hmmm?
   / I hope Amsoil synthetic ATH was not a waste of $$$ #44
No, Amsoil was not started by Amway.
   / I hope Amsoil synthetic ATH was not a waste of $$$ #45
I received the information from a dealer here at TBN named CNoel. She sent them to me via the mail. I no longer have the information. This topic has come many times (imagine that?) she saw my posts and thought I would want the information which she recevied at a national Kubota dealers meeting. I had Amsoil synthetic in a Kubota L4850 at the time.
   / I hope Amsoil synthetic ATH was not a waste of $$$ #46
I guess I should be asking which Amsoil product you are using instead. :)
For the front axle:
(SVG) SEVERE GEAR™ Synthetic Extreme Pressure (EP) 75W-90 Lubricant
(SVO) SEVERE GEAR™ Synthetic Extreme Pressure (EP) 75W-140 Lubricant
(AGL) SAE 80W-90 Synthetic Gear Lube, GL-5, MT-1
(FGR) Long Life Synthetic Gear Lube SAE 75W-90
(FGO) Long Life Synthetic Gear Lube SAE 80W-140
(AGM) Universal Synthetic Marine Gear Lube SAE 75W/80W-90
For the transmission:
(ATF) Synthetic Universal Automatic Transmission Fluid
(CTG) SAE 10W Synthetic Powershift Transmission Fluid
(CTJ) SAE 30 Synthetic Powershift Transmission Fluid
(CTL) SAE 50 Synthetic Powershift Transmission Fluid
(ART) Synthetic Supershift® Racing Transmission Fluid
(MTF) Synthetic Manual Synchromesh Transmission Fluid
(MTG) Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
(ATD) Torque-Drive™ Synthetic Automatic Transmission Fluid
(ATH) Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30
(SVG) Severe Gear Synthetic Extreme Pressure (EP) 75w-90 Lubricant
(FGR) Long Life Synthetic 75w-90 Gear Lube
   / I hope Amsoil synthetic ATH was not a waste of $$$ #47
If you are sharing transmission with hydraulic oil…. You will want Amsoil ATH in the transmission. For the front drive it will also work well also, but you can use just about any quality gear lube (synthetic preferred), check the specs and watch that it meets or exceeds your needs.
I have been reading oil specifications for decades and I have never found a mineral base oil that came close to any true synthetic. It’s too bad you can not find that literature I would like to read anything like technical specifications on UDT/SUDT, I would find any comparison to synthetic very interesting. KennyV.
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2006 TerraGator 8104 (A55314)
2006 TerraGator...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A55851)
2025 JMR 36in...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
