i know it's reality...
   / i know it's reality...
tried - not for a couple of minutes but a while - also tried back to back too many times and nothing - gets abit warmer and starts no problem. got serious snow here yesterday and today and I have a tractor statue! will try tomorrow after topping the battery off again. sucks to be honest!
   / i know it's reality... #34
I checked my glow plug rail with a multi-meter, it's only powered up while the glow plug light is on.
I just wanted to let you know, since I was the one that suggested to turn the key on and walk away for a few minutes...
not knowing much i thought that! Thanks!!!!
   / i know it's reality... #36
   / i know it's reality... #37
Most modern tractors have drain, at bottom of the main fuel filter. If your has a lot of moisture it is likely frozen and stopping fuel flow. Use a hair dyer or the like to warm bottom of fuel filter then open drain and turn your key to run (not start) which will operate fuel pump. Continue until you get pure fuel out then turn key off and close drain. If fuel is your issue tractor should start.
Good luck!
Sent from my iPad using TractorByNet
   / i know it's reality... #38
If I turn my ignition switch all the way back it will bring on the glow plugs for as long as it is held in that position. Probably many different setups for this but just a thought. I use a block heater and the glow plugs seldom come on if it has been plugged in.
   / i know it's reality... #39
Nothing can tick me off more than the issue you are having and its not just the color of the tractor ... My JD 5520 is the worst to start under 35 degrees ... I've just learned thats the way it is ... so I park the heifer in the shed and put the torpedo heater on it while im doing the feeding of grain ... then crank the heifer to haul hay ... Ive called her alot of names !!!
   / i know it's reality... #40
How much power is it getting?
(4) Magnatex Pumps (A50121)
(4) Magnatex Pumps...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
1267 (A50490)
1267 (A50490)
2011 Ford F-250 4x4 Ez Dumper Pickup Truck (A50323)
2011 Ford F-250...
