I Match Hitch
   / I Match Hitch #11
For both need bushings, or it is a pretty loose fit.
My SpeeCo bushings were a set for $12.95, without the top link bushing. That is the Cat I to Cat III set.
   / I Match Hitch #12
</font><font color="blue" class="small">( If you have to adjust it for each attachment you hook up to, I don't see the benefit over the Pat's eay change system. I must be missing something. )</font>
I am missing it also /forums/images/graemlins/confused.gif
   / I Match Hitch #13
kennyd
beenthere is right, we usually do like what we have best, but I went with the Speeco because of the adjustable top link. (plus I saw it with a great price at TSC /forums/images/graemlins/grin.gif)
I certainly don't want to change that top link position, but you just know at some point it's gonna save ya from using the welder to make an attachment imatch compatible!
Joe
   / I Match Hitch #14
I forgot to ask, does Pat's Easy Change System need bushings ?
   / I Match Hitch #15
Go to the website of Freedom Hitch and you will find the best quick hitch on the market in my opinion. No need to get off the tractor unless there is a pto to hook up. Works great and I love mine. Works with any make and model of attachments.
   / I Match Hitch
So you help re inforce the short liners that try to save a nickel by not making their implements meet the ASAE standard??? /forums/images/graemlins/confused.gif
   / I Match Hitch
If your implements met the ASAE standard, they WOULD all be the same width
   / I Match Hitch #18
The best way I can explain this is by example; My box blade hooks up with the standard Speeco top hook. My brush cutter doesn't need the top hook, it has a flexible hinge that interferes when going through ditches so I remove the hook (I exchanged the bolts for removable pins). My tiller also can't use the top hook, it has a massive top attachment point, with the hook in place it is extremely difficult to align, the tolerances are too tight. With the tiller I simply use two quick pins and line up the top holes on the Speeco, works perfect.
I know I could replace/modifly equipment, but I don't feel the need, all of my attachments hook up in less than a minute with no hassle. Ultimately I agree with the earlier post "we have what we like best", you need to do what works best for you, the Speeco just offers more flexibility without the need for welding/cutting, or replacing implements. Good Luck!
   / I Match Hitch #19
Thanks for the info on the speeco. I did not know the speeco top hook could be changed that quick. All the pictures I had seen had bolts and I "assumed" that is what it had to have. I am always learning something on this site. This may indeed be a good option for the orginal poster.
   / I Match Hitch #20
I checked the Freedom Hitch web site. Very little info and not a good picture of it either. I did request the info tape. We'll see.
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
1837 (A51248)
1837 (A51248)
