I MUST BE GETTING BLIND AS A BAT,
   / I MUST BE GETTING BLIND AS A BAT, #1
escavader
western maine
bx-23 ,
Can you paint a dipstick white,or use fingernail polish or something,or will it disolve from the oil?The super udt in my KUBOTA tranny is tough to see on that dipstick,the stuff is almost clear.thanks ahead
ALAN
   / I MUST BE GETTING BLIND AS A BAT, #2
NH 134 is the same way. I blot the stick on a clean paper towel. The wet strip on the paper shows up much better than the oil does on the stick.
   / I MUST BE GETTING BLIND AS A BAT, #3
Rick, that is a good Idea. I was wondering if there was colored hy/tran oil. I don't have any trouble seeing engine oil. After the first day it is black as night.
Chris
   / I MUST BE GETTING BLIND AS A BAT, #4
I always drill a 1/16" hole right at the FULL mark on my dipsticks. It make a big difference in seeing the oil at the mark.
Just did my new 15kw Generac's dipstick last week...
   / I MUST BE GETTING BLIND AS A BAT, #5
Joys of the Bifocal age!! Then there are the little black floaters to help matters.
The drilled hole sounds like a very good idea.
Egon
   / I MUST BE GETTING BLIND AS A BAT, #6
Just a slight dimple with a center punch will help also.
   / I MUST BE GETTING BLIND AS A BAT, #8
Like the gentleman said... the hole drilled is the key. I do one at full mark and at add mark. I also take really fine steel wool every now and then and clean the dip stick keeping it shinny and new.
Jim
   / I MUST BE GETTING BLIND AS A BAT, #9
I knew a guy who painted the end of his dipstick white, up to the full line. I'd think if you clean the stick well enough and give the paint plenty of time to dry and cure, this should work for quite a while.............
   / I MUST BE GETTING BLIND AS A BAT, #10
Take a pass across the full line with the edge of a small file, it will make it easier to see.
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
