I MUST BE GETTING BLIND AS A BAT,
   / I MUST BE GETTING BLIND AS A BAT, #1
escavader
western maine
bx-23 ,
Can you paint a dipstick white,or use fingernail polish or something,or will it disolve from the oil?The super udt in my KUBOTA tranny is tough to see on that dipstick,the stuff is almost clear.thanks ahead
ALAN
   / I MUST BE GETTING BLIND AS A BAT, #2
NH 134 is the same way. I blot the stick on a clean paper towel. The wet strip on the paper shows up much better than the oil does on the stick.
   / I MUST BE GETTING BLIND AS A BAT, #3
Rick, that is a good Idea. I was wondering if there was colored hy/tran oil. I don't have any trouble seeing engine oil. After the first day it is black as night.
Chris
   / I MUST BE GETTING BLIND AS A BAT, #4
I always drill a 1/16" hole right at the FULL mark on my dipsticks. It make a big difference in seeing the oil at the mark.
Just did my new 15kw Generac's dipstick last week...
   / I MUST BE GETTING BLIND AS A BAT, #5
Joys of the Bifocal age!! Then there are the little black floaters to help matters.
The drilled hole sounds like a very good idea.
Egon
   / I MUST BE GETTING BLIND AS A BAT, #6
Just a slight dimple with a center punch will help also.
   / I MUST BE GETTING BLIND AS A BAT, #8
Like the gentleman said... the hole drilled is the key. I do one at full mark and at add mark. I also take really fine steel wool every now and then and clean the dip stick keeping it shinny and new.
Jim
   / I MUST BE GETTING BLIND AS A BAT, #9
I knew a guy who painted the end of his dipstick white, up to the full line. I'd think if you clean the stick well enough and give the paint plenty of time to dry and cure, this should work for quite a while.............
   / I MUST BE GETTING BLIND AS A BAT, #10
Take a pass across the full line with the edge of a small file, it will make it easier to see.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
