I need a salt/sand spreader
   / I need a salt/sand spreader #1
Casco1
New England
Kubota L series
I have a bad driveway, steep and with a curve. It needs to be sanded after it's cleaned up. I'd rather not do it by hand so I've been thinking of a spreader that I can mount in a receiver I welded to my FEL bucket and wire to my electrical system. I don't want junk but $1000 seems a little steep. Does anyone have any suggestions or experience with these.
   / I need a salt/sand spreader #3
Casco1--
From the looks of your drive, I think you'll need something with a decent capacity. I've used a cone spreader similar to the one pictured from TSC, but it is a King Kutter or Cosmo (all made in Italy) and has a 500#+ capacity and operates off my 3PH. Been very reliable for the past four winters, easy to use and was less money than the one pictured--I think just under $300 on sale. I put a sand and ice melt mixture in mine and the throw pattern is adjustable. Just something for you to consider....
Regards, Mike
   / I need a salt/sand spreader #4
I agree with the michelob. I just bought the KK/Cosmo 3ph/pto driven cone spreader and paid about $400 for it. I had a load of sand delivered prior to the snow fall. I used it for the first time the other day and it worked great. I did have to bounce the 3ph up and down a bit to keep the sand flowing. I think a coarser/bigger sand would work a little better then what was delivered but it was all I could get at the time.
Its been a learning process. They do hold a lot of material. One thing to consider, is using chains. My tractor has 4WD but I put my tooth bar on and backed down my driveway while the sand was being spread. This gave me some traction as I went down because I don't have chains yet but I wish did.
Good luck,
Craig
   / I need a salt/sand spreader #5
Your driveway looks like mine, except mine's in the woods with 2 curves. I just run the toothbar over it when things get slick to rough up the surface, then follow up with the back blade a bit off the ground to spread out the debris.
   / I need a salt/sand spreader #6
i use a 4n1 bucket.you can clean the drive with it and you do not have to hand load the spreader.i go through about 10/14 yds per winter:eek:
   / I need a salt/sand spreader #7
I have a spreader that I bought from CCM, I think a 500#. I wash that thing more than my socks and it still gets rusty, and that is just from lyme and fertilizer. I was thinking about using it for a sand/salt mixture, are these things rotting off the back of your tractor?
PaulChristenson said:
If you have a receiver attachment, this is the way to go...:D
Baby Sandspreader
I looked at the website, I was impressed, I wonder what it sells for.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
402 (A52706)
402 (A52706)
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
