I purchased a Pressure tester/Adjustment kit Any tips? 2100 PSI good starting point? BX25.
   / I purchased a Pressure tester/Adjustment kit Any tips? 2100 PSI good starting point? BX25.
So I tested the Pressure after warming the machine up for about 15 Min and running the loader and back hoe though its motions, I got 1,800 PSI. I put in the 2 thickest shims and it jumps to 2,200 but then settles right down to 2,000 PSI. I was looking for 2,000 PSI but am I supposed to go by the reading it spikes to for a second or the one it settles down to.?
   / I purchased a Pressure tester/Adjustment kit Any tips? 2100 PSI good starting point? BX25. #12
Just a note of WARNING! ;-)
I put an after market three spool valve on my Hurlimann 435. I could tell right off that the over pressure relief was set lower on the new valve. I considered bumping up the relief pressure.
About when I was getting ready to do so, I was using the loader to dig out a stump and wouldn't you know....
I broke the front axle casting!
I have not even considered upping the hydro pressure to increase lift or break out after replacing the axle. That was a lot of work!
I watched a few videos of people adjusting there pressure and theirs seemed to climb steady to max pressure and not go over, Mine does go over by 200 PSI briefly and drop. I Don't think that surge should cause an issue but I am curious why mine does it.
It is more twitchy more noticeable with the backhoe.
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2013 Ford Edge (A54815)
2013 Ford Edge...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
