I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor
I do have some questions about your Meteor though. We haven't had much snow so you shouldn't of experienced any power loss. Were you loosing power or was it more a case of it just wouldn't throw snow. If it just wasn't throwing snow then you may have an impeller clearance issue. I almost never run at more than 2000ish with my blower. Being a front mount with a mid PTO I should have less HP going to it.
LOL looks like I voided the warranty on the blower too Al. No experience with a snowblower. We had 5 inches Thanksgiving morning. I blew snow and rocks till I was blue in the face.
Are you currently using ULSD in the tractor?
NO, My fuel was bought in 1995, no crap but it works fine in every other Diesel I own. What does ULSD have to do with it?
Fred
   / I Still Hate My Tractor #212
"NO, My fuel was bought in 1995" !!!!!!!!!!!
& all this time & $ with your expertise using 18yr old fuel? could that alone be the smoking/starting problem? cheers, best of luck
I've tried both doesn't make any difference. Go start a thread about using old fuel.
The dealer knew this before I signed any paperwork.
Fred
   / I Still Hate My Tractor #214
Your engine is a "Interim Tier4" engine is it not? (it appears to be from http://www.kubota.com/product/L40/pdf/gl40_spec.pdf ). If so, Kubota says that "Ultra Low Sulfur Diesel (15 ppm or less)" is required (per: Kubota Service Lubricant Maintenance )
Before you go further, I would try draining the tank and filling it with ULSD to see how it does then.
Aaron Z
Aaron I have already, NO difference.
What makes you the fuel expert? Kubota manual states NO high sulfur fuel to be used with this engine. THEN in maintenance it says 200 hr. oil service interval UNLESS using high sulfur fuel then 100 hr. interval. My fuel is fine. Now we have a forum full of fuel experts.
Aaron do think all parts of the world have ULSD fuel? Highly doubtful.
Ultra-low-sulfur diesel - Wikipedia, the free encyclopedia
Like I said start a fuel thread.
Fred
   / I Still Hate My Tractor #216
Fred I checked the fuel thread and the biggest issue would be that some of the slime is restricting your fuel filter. You may not be able to see it but the flow is restricted and even though you changed fuel, did you also change the fuel filter? . . . OK I'm leaving and going back to the fuel thread, just my 2 cents in this very interesting thread.
   / I Still Hate My Tractor #217
While synthetic oils tend to be molecules of the same length, density, or whatever crude oil is 'cracked' (separated by gravity) into groups of similar molecules that are a blend to some extent in each general category. Heavies become diesel grades, lighter are kero, gas, etc. (source: API)
I drained nasty old gas from a tractor into milk jugs and capped them for disposal. Just as the fizz can dissipate from a plastic soda bottle over time (months) there has been a smell of ether near the jug. I guess it's smaller moleculeswithin the 'blend' can seep thru' the HDPE just as CO2 seeps thru the clear stuff and alter the formula. So, what if the old diesel has lost some lighter components of its blend and rendered it to a lower grade, not thick 'bunker', but say '#3' or so over the years. I doubt sulphur would be the first to be lost, & apparently it's a non-issue here.(?) Sorry to mention fuel, again ...
Could there be something amiss with digital controls somewhere, as when an auto ECM/EEPROM is mismatched to the vehicle, or the install, and needs to be checked out on a high-end analyzer? (Wrong/defective chip, etc) I was taught in college that 'proper diagnosis is the direct way to the right fix'. There are just so many thinks to check out here and we seem to be spinning our wheels to this point. :mur:
Trying not to over-think the possibilities Fred, honest.
   / I Still Hate My Tractor #218
This just gets more interesting everyday! :D
   / I Still Hate My Tractor #219
Looks like a post got deleted? I was looking forward to my mickey Ds' gift certificate :confused:;).
   / I Still Hate My Tractor #220
People continually telling you how wrong you are has to get old for any one. From what I've seen here I know that your skillset surpasses mine in this arena.
If you need more info you could try using the private messaging to some of the members that have contributed good info to your thread instead of posting back here to get beat up on.
If you do drop this thread I hope that you will start another thread to show off the completed project after you get her buttoned up.
Status
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
RoGator RG1100C (A55315)
RoGator RG1100C...
Enmark Z Spray (A53316)
Enmark Z Spray...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
2021 Ford F-150 (A55973)
2021 Ford F-150...
