I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor #241
I have heard a couple of references on this thread as to how you can run a gear tractor at lower RPMs but an HST poops out. My understanding is that's not because the HST is sapping HP or anything like that, but because the hydraulic transmission requires good flow rate (i.e. RPMs) to work properly. I have only ever owned an HST tractor, so I'm aware I'm not exactly coming from a position of knowledge, but when I got it, I was told that it needed to be run at close to PTO RPM or it would bog down and act under-powered, and that has been my experience. It's not that the HST has less torque than the gear--and, at the end of the day, if it can spin the wheels, then it's got more torque than you need--but that if you try to run an HST like a gear tractor, trundling away and letting the throttle control the speed, you'll get bad results. I suspect that more than a few bad reviews of HST tractors are coming from people with years of experience behind a gear tractor, who haven't yet figured out that you have to run the throttle differently. And then when they have to run at max throttle all the time, they think it's because the HST is under-powered, when that's not the case. Not saying that's what's going on here, necessarily, just throwing out two cents.
(Which is not to say that the HST doesn't sap some HP, just that it's not a huge amount, and not enough to make up the difference that some folks talk about.)
   / I Still Hate My Tractor #242
Read most of this thread and got tired. Simple my business agent told me-If your not happy you can quit! If your not happy Sell it.
   / I Still Hate My Tractor #243
Thought it was Christmas elves that come out at this time of year not there uglier/nastier cousins...
   / I Still Hate My Tractor #244
Only way I can drag the L5030 down is using the hydraulics combined with large PTO load or pulling large trailer up hill. Deadhead and it will almost stall the tractor if it was already loaded down. If just sitting there it barely changes the rpm.
Try "deadheading" the loader, by curling back and hold it there for a couple of seconds while the pump goes over the relief valve, and see what it does,, I bet about 150 maybe 175 drop. If you think of it, tomorrow when you feed another bale of hay, see what it does with a big ole round bale on the spear. I don't think it will drop much, but it may a little
James K0UA
   / I Still Hate My Tractor #245
My fuel was bought in 1995, no crap but it works fine in every other Diesel I own. What does ULSD have to do with it?
Fred
I'm a Fred fan, but I have to ask this. Did you inherit a diesel tanker truck? How does one come upon enough diesel to last since 1995?
   / I Still Hate My Tractor #246
Maybe he is a "prepper":laughing:
   / I Still Hate My Tractor #247
Tom - in the post that got quickly deleted he said he had it in his basement. ???
   / I Still Hate My Tractor #248
Go Fred. He lives on top of an oil well he bought in 1995. I need one of those.
   / I Still Hate My Tractor #249
Though Fred doesn't seem to want to discuss fuel as a possible element in his tractor's poor performance he may be missing the point that all his other diesel equipment runs fine on vintage diesel his new 'Bota is much more sensitive to what it burns. And service manuals are notoriously out of date as to the latest specific model year issues like what fuel to burn, or not to burn. Sometimes supplements are put out that are up to date, but it depends on the manufacturer. The same basic machine can be put out in different markets in different countries and specked for different local fuel usage, but the buyer is likely not going to know what differences are incorporated into each market's particular design, parts use, etc.
So though fuel may not be the cause and effect, it could be exactly that; and it is the one thing everyone else is NOT using on identical market machines. Something to consider, and easy enough to test out.:confused3:
   / I Still Hate My Tractor #250
This afternoon when my wife and son got finished feeding the cows and bedding up the cow shed I tried something with the L3940. I set the RPM's to 2000 and operated the FEL, empty I might add except a HD Round Bale Spear, and the RPM's never dropped lower than 1900. I done this about 5 times up and down just see what it would do.
Wow, it dropped 100 rpms just by activating the loader hydraulics with no tractor movement and the engine in it's peak torque range (2000 rpm)??? I think yours is worse than Fred's, at least his tractor is moving and operating the loader hydraulics at the same time. Try driving up an incline in mid range half throttle (1500 rpm or less) with a bale on and operate the loader hydraulics.
Status
Adams 16T Tender Body (A56436)
Adams 16T Tender...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
