I thought I'd seen it all.....
   / I thought I'd seen it all..... #1
CAgnoli
Kiantone, NY
Kubota Grand L 3940 HST-3
I'm not sure if I got the picture attached, but this is a friend of a friend who was apparently transporting a load too heavy for his 2305 without a ballast box.....:)
   / I thought I'd seen it all..... #3
Ah the physics of load balancing… by the bye was your friend wearing his seat belt?
   / I thought I'd seen it all..... #4
If he wasn't, he is probably laying out of the picture to the right!;)
   / I thought I'd seen it all..... #5
Hahaha.... the friend isn't in the picture as he went in to clean out his shorts!!
The 2000 series are barely larger than lawnmowers; I'm surprised we don't see more of these pictures given the types of stuff their owners put them through on this board. (I'm used to full size tractors & backhoes, so my 970 seems pretty dinky to me.) Then again, it is a testament to the quality of the units if they hold up to this abuse.
   / I thought I'd seen it all..... #6
Yikes!! I don't know about that series of J-D's, but my 955's front brakes don't work if the 4wd isn't engaged, so, if you're hauling a bit more weight than you should in 2 wd and the rear wheels come off the ground, the brakes don't work. Now THAT gets your attention.
   / I thought I'd seen it all..... #8
Another great reason to keep a loaded bucket low during transport. From the looks of it, his bucket had to be 5' or 6' off the ground?
   / I thought I'd seen it all..... #9
3RRL,
That was my thought immediately when I saw the post, traveling with a load well off the ground, hit a dip and it flipped towards the front. If this is the case, be sure to tell your friend, if transporting weight to keep it very low/almost against the ground. Alternatively, if he had tried to turn with a load transporting it well above the ground, then the picture would have been of that new 2305 on it's side.
I sure hope he has learned a valuable lesson about the need for BALLAST :eek:
   / I thought I'd seen it all..... #10
Ahh -- It's a posed photo.:D
I can do that with my Kubota B7100 anytime I want. :)
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
