I tipped my Kubota!
   / I tipped my Kubota! #41
I am sure this has been said before but none of these small utility tractors have anywhere near enough weight on the back. Loaded tires is not enough either. Loaded tires plus wheel weights helps but the best is weight hung out behind on the 3pt. I can still bring the back of my L5740 off the ground with wheel weights and 1400# on the 3pt.:eek:
Took the new to me JD3005 with a 300 fel for a quick drive on daughters pasture. I have mowed it with old 1010 for 11 years. It is not level, but not too hilly. I did not feel at ease like I do with the old tractor. tires are loaded, and the largest for that model. Does heavy ballast at the 3PH stabilize them sideways???
Looking at the front of the engine, which direction do I turn the engine crank shaft? (Clockwise or counter clockwise?)
Thanks.
   / I tipped my Kubota! #43
Stability is mostly provided by the rear tires. Note how the front axle floats up and down, side to side, on uneven ground.
So yes, stability is provided by the rear tires and yes, weight on the 3pt helps stability. Also, make sure the tires are set to maximum width, especially the rear tires.
Ken
   / I tipped my Kubota! #44
Thanks.
To be absolutely certain look at the configuration of the fan blade. turn the engine in the direction that would have the fan pulling air through the radiator.
   / I tipped my Kubota! #45
Not to down play the significance of the risk of rolling over but working on hillsides is part of the reality of farming. The uncomfortable feeling is often the operator sensing the lean because your head is much higher than the center of gravity of the tractor (and your butt sliding on the seat) - usually well before you're near rolling it over. Still - as many have said already low and slow AND keep an eye out for changes in pitch of the hill. Watch for gopher/badger holes too.
Out here the wheat farmers run "hillside combines" that have self-levelers on them - hydraulics that keep the body of the combine level while the wheels and header stay on the hill's contour.:confused2:
   / I tipped my Kubota! #46
For anyone that has insurance through Kubota, don't worry about getting a tow truck or waiting for an adjustor to come out. We work with your Dealer so you don't have to worry about delays or dealing with someone that may not care if you are satisfied with your "Kubota" experience. Call your Dealer A.S.A.P. and ask them to come pick it up then you need to call us to file the claim (800-348-5802). We will contact the Dealer and have them send us the cost of repair and the cost of transportation... that's it. We usually have the money to the dealer for the repair before the parts are there! :thumbsup:
PS - Glad to know you are okay!
   / I tipped my Kubota! #47
Thanks.
Clockwise from front. 99.99% of all engines turn the same direction, CCW (left hand rotation for old timers) when viewed from the flywheel (pto) end. All of Kubota engines are CCW from flywheel. Philip.
Thanks.
   / I tipped my Kubota! #49
We sure hope you are ok, and secondly your tractor is OK, You already know not to crank the engine without proper check out. Check battery for cracking/spillage, Best to take it out, and look under it for seepage. Its a hard lesson, and I am sorry you had to learn it. Proper ballast, never lift the loader when it has a load unless you are stopped like loading a dump truck or something, always always carry a load as low as possible. But you already know these things. I only post them for the sake of others. I would let the wrecker driver decide where to attach, Most of them have a lot of experience and a lot of common sense about such things. I believe the Kubota insurance will pay off, but there is still the deductable for you. Again I sure hope you are all ok, as any damage to the machine can be fixed pretty easily.
James K0UA
Most understand the rules but may not apreciate why things can go south so quickly. A few basic principals behind why you should keep the load low to the ground and set it down fast if you get that about to float feeling from the rear of the tractor:
With the front axle mounted on a lateral pivot bearing, normal tractor rollover stability comes from the rear wheels only. When they get light or worse case lift off the ground , not only are you pivoting back to front on your front axle but you now free the tractor to pivot without restriction sideways on the axle pivot the moment the center of gravity (cg) of the tractor mass plus FEL load mass finds itself off laterally the vertical from axle pivot. You might hit the 1 in a million chance they actually line up (for a moment or two) - otherwise you're going over. Once you start to tip, the farther machine rotates to one side the farther the total tractor cg moves outboard from the axle pivot vertical and the more righting moment or force it takes to stop the process. Also the higher the FEL load cg (raising the height of the total tractor cg) the faster/farther the combined cg moves outboard for every degree of rollover rotation you go thru. In other words once you start to go over, you'll not only keep going over but will probably pick up speed unless you can quickly dump the FEL load and put load back on the rear wheels effectively moving your stability tipping point outboard of the total tractor plus load cg . Obviously there's a point of no return where once you've tipped far enough your total cg has traveled outboard the stability cg envelope of the tractor and your going over no matter what.
Point is if the rear wheels are up you effectively have no side to side stability and you should plan on rolling over sideways until the load is back on the ground either because you put it there or the tractor put it there the only other way it knows how...
   / I tipped my Kubota! #50
Another reason I chose the Kubota ins. over my homeowners ins. :thumbsup:
T/A 16 TRASH TRAILER (A55745)
T/A 16 TRASH...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2022 CATERPILLAR 246D3 SKID STEER (A52707)
2022 CATERPILLAR...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55314)
BOSS 990 Fuel...
