I want a Canon Powershot SD300 camera
   / I want a Canon Powershot SD300 camera #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hi All,
Years ago I modified a Canon Powershot SD300 to take pictures in the near infrared and near UV. To do this I had to take the camera apart to remove an internal filter and replace the filter with a piece of quartz glass made from a microscope slide the same thickness as the filter I removed. I now use filters in front of the camera to only let in IR or UV or both. Somehow the LCD screen on the camera suffered damage so I need a new one. This is just a silly hobby of mine that I don't spend much money on, so if anyone here has one of these old cameras not being used and would like to part with it for little to no money I would love to take it off of your hands. I have tried ebay several times but nobody will or can test the LCD screen on the parts camera they are selling and I don't want to buy a bunch of cameras just to find out that the one part I need doesn't work. As I said, this is a cheap hobby. But I do get some interesting pictures now and then.
Thanks,
Eric
   / I want a Canon Powershot SD300 camera #2
Greetings Xfaxman,
Thanks for the reply and the link. I will try to see if someone there can help me. I can buy a working camera but all I can find at the moment are more money than I can justify for a silly hobby. I especially like your suggestion that the LCD from other camerea models might work. I am getting some really cool pictures though. Looking through the UV filter makes for some interesting stuff. BTW, for the UV filter I bought a blacklight light bulb. The glass was, I assume, Wood's glass. Anyway, I turned on the lathe a plastic filter holder that fits over the camera lens and holds either the UV or IR filter. Then I made a saw from bronze that I charged with diamond paste. I used the saw to cut discs from the bulb. The discs are of course rounded but it doesn't seem to make much difference to the pictures. I made IR filters from old floppy discs using a gasket punch.
Eric
Pictures, we need pictures.
I found a Powershot SD400 for 20 bucks and it appears to be the same camera except it has a higher pixel count and some othet features not found in the SD300. It arrives soon so I am going to modify it the same way. When done I will post pictures from it.
Eric
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
Electric Concrete Mixer (A51573)
Electric Concrete...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
